StarTech.com 2-Post 8U Wall Mounted Rack
Quicklinx: J7Y1WS00 Mfr#: WALLMOUNT8-HAF
£70.34 ex VAT
£84.40 inc VAT
The 2-Post 8U Wall Mounted Rack by StarTech.com is a durable solution for space-constrained environments. Constructed from robust 14 gauge steel, this rack is designed for wall mounting, ensuring that it occupies minimal floor space while providing accessible storage for equipment. Its open frame design supports optimal airflow, granting users easy access for maintenance and organization of network components.
With a height of 8 rack units and a standard width of 19", this wall-mounted cabinet is compliant with EIA-310-E and ECA-310-E standards, ensuring compatibility with various equipment types. The included package comes complete with necessary accessories, such as M5 cage nuts and screws, making installation straightforward. With a weight limit of up to 40 kg, this rack is capable of supporting a range of network devices to accommodate growing IT infrastructure needs.
  • Sturdy construction
    Made from 14 gauge steel, this rack provides durability and stability, ensuring that equipment is securely housed.
  • Space-saving design
    The wall-mountable feature allows for installation in tight areas, maximizing floor space while keeping essential equipment within reach.
  • Easy installation
    Comes with necessary hardware including cage nuts and screws, facilitating a quick setup process.
  • Open frame for airflow
    An open design enhances ventilation, helping maintain optimal operating conditions for installed equipment.
  • Compliant with industry standards
    This rack meets EIA-310-E and ECA-310-E standards, ensuring compatibility with a wide range of IT devices.
StarTech.com 2-Post 8U Wall Mounted Rack, Adjustable Depth Server Bracket - cabinet - 8U
Cabinet
Placing / Mounting
Wall mountable
Package Content
24 M5 x 15 screws, 24 M5 cage nuts, 4 M8 x 50 screws, 4 M6 x 12 screws
Rack Size
19"
Height (Rack Units)
8U
Product Material
14 gauge steel
39.77 cm 38.35 cm
7 kg
2-post, open frame, square hole
Cabinet
Placing / Mounting
Wall mountable
Product Material
14 gauge steel
Package Content
Rack Size
19"
Height (Rack Units)
8U
39.77 cm
38.35 cm
Adjustable Depth
24.53-39.77 cm
7 kg
58.5 cm x 45.5 cm x 10.5 cm / 9.1 kg
Weight Limit
40 kg
ECA-310-E, EIA-310-E
Limited warranty: - lifetime
J7Y1 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
J7Y1 StarTech.com 10-32 Server Rack Screws and Nuts - 50 Pack - Black - TAA Co In Stock £29.04
