The 2-Post 8U Wall Mounted Rack by StarTech.com is a durable solution for space-constrained environments. Constructed from robust 14 gauge steel, this rack is designed for wall mounting, ensuring that it occupies minimal floor space while providing accessible storage for equipment. Its open frame design supports optimal airflow, granting users easy access for maintenance and organization of network components.
With a height of 8 rack units and a standard width of 19", this wall-mounted cabinet is compliant with EIA-310-E and ECA-310-E standards, ensuring compatibility with various equipment types. The included package comes complete with necessary accessories, such as M5 cage nuts and screws, making installation straightforward. With a weight limit of up to 40 kg, this rack is capable of supporting a range of network devices to accommodate growing IT infrastructure needs.
Sturdy construction
Made from 14 gauge steel, this rack provides durability and stability, ensuring that equipment is securely housed. -
Space-saving design
The wall-mountable feature allows for installation in tight areas, maximizing floor space while keeping essential equipment within reach. -
Easy installation
Comes with necessary hardware including cage nuts and screws, facilitating a quick setup process. -
Open frame for airflow
An open design enhances ventilation, helping maintain optimal operating conditions for installed equipment. -
Compliant with industry standards
This rack meets EIA-310-E and ECA-310-E standards, ensuring compatibility with a wide range of IT devices.
- StarTech.com 2-Post 8U Wall Mounted Rack, Adjustable Depth Server Bracket - cabinet - 8U
- Product Type
- Cabinet
- Placing / Mounting
- Wall mountable
- Package Content
- 24 M5 x 15 screws, 24 M5 cage nuts, 4 M8 x 50 screws, 4 M6 x 12 screws
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 8U
- Product Material
- 14 gauge steel
- 39.77 cm 38.35 cm
- 7 kg
- 2-post, open frame, square hole
- Limited lifetime warranty
- Product Type
- Cabinet
- Wall mountable
- Product Material
- 14 gauge steel
- Package Content
- Rack Size
- 19"
- 8U
- 39.77 cm
- 38.35 cm
- Adjustable Depth
- 24.53-39.77 cm
- 7 kg
- Shipping Dimensions (WxDxH) / Weight
- 58.5 cm x 45.5 cm x 10.5 cm / 9.1 kg
- Black
- Weight Limit
- 40 kg
- ECA-310-E, EIA-310-E
- Limited warranty: - lifetime
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £12.34 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.49 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.56 |
