This 2-Port VGA Video Splitter allows a computer to display VGA video on two monitors simultaneously. Perfect for classrooms, tradeshows, or any environment requiring high quality video on several monitors, the ST122LE VGA splitter supports displays with up to 300 MHz of bandwidth and up to 2048x1536 resolution. Plus, to simplify placement of your VGA displays, the splitter features a built-in booster circuit that allows you to locate VGA monitors up to 200 ft away from your system, and can be powered through a USB connection to the host computer, eliminating the need to find an available power outlet. The ST122LE VGA Splitter supports easy plug and play installation.
- StarTech.com 2 Port VGA Video Splitter - USB Powered - 2048x1536 - VGA Video Monitor Splitter Dual Port (ST122LE) - video splitter - 2 ports
- Video splitter - 2 ports
- Subtype
- VGA
- Ports
- 2 x VGA
- 110 g
- Black
- System Requirements
- Microsoft Windows Vista / XP
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- VGA
- Ports
- 2 x VGA
- Max Resolution
- 2048 x 1536
- Max Video Bandwidth
- 300 MHz
- 2 x VGA HD-15 , 1 x VGA HD-15
- Black
- FCC, RoHS
- OS Required
- 110 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.01 |
Resources
The following resources are available for the StarTech.com 2 Port VGA Video Splitter - USB Powered
Customer reviews
Write a review for the StarTech.com 2 Port VGA Video Splitter - USB Powered here!
Works as described
Reviewed by David Smith. Review Posted 26/09/2009
Does what it says on the tin! We needed some more splitters and didn't want to go for the box-type which also need a spare power socket (and are bigger).
This thing does the exact same thing, is alot smaller (you barely notice it), and powers from USB, so no need to find a spare plug socket! Bought 2 and both have been fine.
No worries about lack of power (some unpowered ones suffer from a dull image) - this provides an image just as good as the conventional splitters.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
