StarTech.com 2-Port VGA Auto Switch Box with Priority Switching and EDID Copy
Quicklinx: 93K3WS00 Mfr#: ST122VGA
Type: Monitor switch
Ports: 2
Connectivity: VGA
£56.36 ex VAT
£67.63 inc VAT
Share a VGA monitor/projector between 2 VGA sources, with automatic/priority switching and EDID Emulation. The ST122VGA 2-Port VGA Auto Switcher lets you share a display between two computers and automatically switch to the active source device using configurable priority switching. When the port you have selected as the primary input is turned off, the device automatically switches to the secondary input.
For maximum control and versatility, the ST122VGA also offers manual switch control with an easy-to-use button that allows you to toggle between video sources.
For a convenient setup the switcher can be powered using the included power adapter or the USB power cable, and features built-in EDID emulation ensuring maximum compatibility with your display or projector and support for resolutions up to 1920x1200/1080p.
The ST122VGA includes mounting hardware for a tidy and professional installation.
StarTech.com 2-Port VGA Auto Switch Box w/ Priority Switching and EDID Copy - monitor switch - 2 ports
Monitor switch - 2 ports
Subtype
VGA
Ports
2 x VGA
KVM Users Qty
2 local users
5.9 cm x 2.1 cm x 7.4 cm
175 g
P/N: SVA5N3NEUA
Enclosure Type
Desktop
Subtype
VGA
Ports
2 x VGA
KVM Local Users Qty
2 local users
Max Resolution
2048 x 1152
Status Indicators
Port status
2 x VGA input HD-15 , 1 x VGA output HD-15
FCC, RoHS
5.9 cm
2.1 cm
7.4 cm
175 g
P/N: SVA5N3NEUA
93K3 StarTech.com 2x1 HDMI VGA to HDMI Converter In Stock £128.61
93K3 StarTech.com 4-Port 4K HDMI Video Switch In Stock £146.05
93K3 StarTech.com 2-Port 4K HDMI Video Switch In Stock £99.96
93K3 StarTech.com DC Power Adapter - 5V, 3A In Stock £12.05
Ports: 2
Connectivity: VGA
