StarTech.com 2 Port USB to RS232 RS422 RS485 Serial Adapter with COM Retention
Quicklinx: 7B5NWS00 Mfr#: ICUSB2324852
10 In Stock
£78.53 ex VAT
£94.23 inc VAT
The ICUSB2324852 2-port, wall-mountable USB Serial Adapter lets you connect every type of serial device to your USB-enabled computer, whether it be for RS232, RS422, or RS485 communication. The adapter features a 9-pin (DB9) male and a 5-pin terminal block serial connector as well as dipswitch controls for easy port configuration with minimal software requirements. The adapter also supports using 2 ports simultaneously, including with mixed protocols; for example RS-232 on port 1, and RS-485 on port 2, or a number of other combinations.
For a convenient, and clean installation in an office or industrial setting, the RS232/RS422/RS485 USB Adapter is wall-mountable and fully powered via the host USB connection, providing power to the attached serial device without requiring an external power adapter.
  • Versatile compatibility
    This adapter is compatible with Mac systems and integrates seamlessly with many devices, providing flexibility for various applications.
  • High-speed data transfer
    Achieve efficient data transfer with speeds reaching 921.6 Kbps, ensuring reliable communication between connected devices.
  • Robust environmental tolerance
    Designed to function in challenging environments, this adapter performs within a temperature range of 0°C to 55°C and handles humidity levels from 5% to 95%.
  • Multiple connection options
    With two ports featuring 9-pin D-Sub and terminal block connectors, this adapter caters to diverse wiring requirements for various applications.
  • Compliant and safe
    Meets FCC and RoHS standards, ensuring adherence to safety and environmental regulations.
StarTech.com USB to Serial Adapter - 2 Port - RS232 RS422 RS485 - COM Port Retention - FTDI USB to Serial Adapter - USB Serial (ICUSB2324852) - serial adapter - USB 2.0 - 2 ports
Serial adapter
External
Interface (Bus) Type
USB 2.0
4.4 cm x 8.2 cm x 2.3 cm
300 g
Ports Qty
2 ports
RS-232, RS-422, RS-485
Data Transfer Rate
921.6 Kbps
Grey
Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0
Serial adapter - 2 ports
External
USB 2.0
Wired
Data Transfer Rate
921.6 Kbps
Status Indicators
USB powered, wall mountable
1 x RS-232/422/485 - 9 pin D-Sub (DB-9) - male , 1 x RS-422/485 - terminal block
FCC, RoHS
Grey
4.4 cm
8.2 cm
2.3 cm
300 g
55 °C
5 - 95%
7B5N StarTech.com DB9 to RJ45 Modular Adapter - F/F In Stock £4.54
7B5N StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £21.20
7B5N StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £30.95
7B5N StarTech.com 1 Port Metal Industrial USB to RS422/RS485 Serial Adapter with Isolation In Stock £107.76
7B5N StarTech.com 6 ft Professional RS422/485 USB Serial Cable Adapter with COM Retention In Stock £63.64
7B5N StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 2 - M/F In Stock £6.32
7B5N StarTech.com 2 Port USB to RS232 RS422 RS485 Serial Adapter with COM Retention In Stock £78.53
7B5N StarTech.com Slimline DB9 Serial Gender Changer - F/F In Stock £4.72
7B5N StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.24
7B5N StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £25.40
7B5N StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £86.44
7B5N StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £148.09
7B5N StarTech.com 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485 In Stock £107.85
7B5N StarTech.com USB to RS232 Serial Adapter In Stock £15.88
7B5N StarTech.com 4 Port USB to Serial Hub In Stock £76.59
7B5N StarTech.com 4-Port USB to Serial Adapter In Stock £207.06
7B5N StarTech.com 8-Port USB to Serial Adapter In Stock £332.34
