StarTech.com 2 Port USB Keyboard Mouse Switch Cable w/ File Transfer for PC and Mac
Quicklinx: 8ZCSWS00 Mfr#: SVKMS2
Type: Direct connect adapter
Connectivity: USB
Ports: 2
Hurry, only 2 left in stock!
£32.24 ex VAT
£38.68 inc VAT
Control and transfer files between two Windows and/or Mac systems using a single keyboard and mouse. The SVKMS2 2 Port USB Keyboard Mouse Switch Cable w/ File Transfer for PC and Mac enables you to control two computer systems using a single keyboard and mouse set, and offers the ability to transfer files between the connected Windows and/or Mac systems.
Offering automated installation (no additional software or drivers required), this compact KM switch cable connects your Windows and/or Mac systems using a standard USB 2.0 port to make switching between systems as simple as moving the mouse over to your second display, or using hot-keys.
This simple 2 port USB KM switch also provides the added benefit of clipboard sharing so you can copy and paste text from one system to another, or drag and drop files for effortless transfers and data management.
StarTech.com 2 Port USB Keyboard Mouse Switch Cable w/ File Transfer for PC and Mac® - USB File Transfer Cable - Dual Port USB KM Switch (SVKMS2) - direct connect adapter - USB 2.0 - USB 2.0
External
Interface (Bus) Type
USB 2.0
Ports
USB 2.0
1.85 cm 1.15 cm
Length
1.8 m
42 g
USB, USB 2.0
USB 2.0
Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14
External
USB 2.0
Ports
USB 2.0
Wired
USB, USB 2.0
Status Indicators
Power, link OK
USB powered, plastic housing
USB 2.0
1 x USB 2.0 - 4 pin USB Type A - male
1 x USB cable (integrated) - 1.8 m
Plug and Play, UL, WHQL, FCC, RoHS
1.85 cm
1.15 cm
Length
1.8 m
42 g
Shipping Weight
121 g
50 °C
85% (non-condensing)
8ZCS StarTech.com 2 Port USB Keyboard Mouse Switch Cable w/ File Transfer for PC and Mac In Stock £32.24
8ZCS StarTech.com 2 Port USB HDMI Cable KVM Switch w/ Audio and Remote Switch In Stock £76.15
8ZCS StarTech.com 4-Port KM Switch, USB Switch In Stock £241.48
Connectivity: USB
Ports: 2
