Control and transfer files between two Windows and/or Mac systems using a single keyboard and mouse. The SVKMS2 2 Port USB Keyboard Mouse Switch Cable w/ File Transfer for PC and Mac enables you to control two computer systems using a single keyboard and mouse set, and offers the ability to transfer files between the connected Windows and/or Mac systems.
Offering automated installation (no additional software or drivers required), this compact KM switch cable connects your Windows and/or Mac systems using a standard USB 2.0 port to make switching between systems as simple as moving the mouse over to your second display, or using hot-keys.
This simple 2 port USB KM switch also provides the added benefit of clipboard sharing so you can copy and paste text from one system to another, or drag and drop files for effortless transfers and data management.
- StarTech.com 2 Port USB Keyboard Mouse Switch Cable w/ File Transfer for PC and Mac® - USB File Transfer Cable - Dual Port USB KM Switch (SVKMS2) - direct connect adapter - USB 2.0 - USB 2.0
- Direct connect adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- USB 2.0
- 1.85 cm 1.15 cm
- Length
- 1.8 m
- 42 g
- Data Link Protocol
- USB, USB 2.0
- USB 2.0
- Black
- System Requirements
- Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14
- 2-year warranty
- Form Factor
- External
- USB 2.0
- Ports
- USB 2.0
- Connectivity Technology
- Wired
- USB, USB 2.0
- Status Indicators
- Power, link OK
- USB powered, plastic housing
- USB 2.0
- 1 x USB 2.0 - 4 pin USB Type A - male
- Cables Included
- 1 x USB cable (integrated) - 1.8 m
- Plug and Play, UL, WHQL, FCC, RoHS
- Black
- OS Required
- 1.85 cm
- 1.15 cm
- Length
- 1.8 m
- 42 g
- Shipping Weight
- 121 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 85% (non-condensing)
StarTech.com 2 Port USB Keyboard Mouse Switch Cable w/ File Transfer for PC and Mac | In Stock | £34.49 |
StarTech.com 2 Port USB HDMI Cable KVM Switch w/ Audio and Remote Switch | In Stock | £78.06 |
StarTech.com 4-Port KM Switch, USB Switch | In Stock | £270.41 |
