StarTech.com 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub
Quicklinx: 6PG5WS00 Mfr#: SV231HDMIUA
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 2
£121.06 ex VAT
£145.27 inc VAT
Share a keyboard, mouse and HDMI monitor between 2 multimedia computers. The SV231HDMIUA 2-port USB HDMI KVM switch lets you control two USB-enabled multimedia computers or devices with HDMI video interfaces, using a single peripheral set/console (USB keyboard, mouse, monitor, speakers and microphone).
A highly versatile KVM solution, the USB HDMI KVM switch features an integrated 2-port USB 2.0 hub that lets selected computers access shared high speed USB devices, eliminating the cost of duplicate USB peripheral purchases.
Ensuring high quality video capability, the HDMI KVM switch supports HD resolutions of up to 1920 x 1200. Offering genuine digital signal transmission over the cable, this switch can be used to share one HD panel between multiple HDMI sources such as Blu-Ray players, video game consoles and HD media centers.
The switch also supports audio and microphone switching functions and allows you to select connected computers, USB device hub ports and audio/mic channels either simultaneously or independently using either front-panel push-buttons or keyboard hotkeys.
StarTech.com 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub - 1080p (1920 x 1200), Hotkey Support - Dual Port Keyboard Video Monitor Switch (SV231HDMIUA) - KVM / audio / USB switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub
AC 120/230 V
12.5 cm x 7 cm x 4 cm
0.8 kg
3-year warranty
P/N: IM12D1500P, SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200
Status Indicators
Port status
2 x USB Type B , 2 x HDMI , 2 x microphone mini-jack , 2 x audio mini-jack , 2 x USB Type A , 1 x HDMI , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x microphone mini-jack , 1 x audio mini-jack
External power adapter
AC 120/230 V
FCC, RoHS
Software Included
Drivers & Utilities
12.5 cm
7 cm
4 cm
0.8 kg
Limited warranty - 3 years
6PG5 StarTech.com 6ft High Speed USB 2.0 Cable In Stock £3.18
6PG5 StarTech.com 15 ft USB 2.0 A to B Cable - M/M In Stock £4.35
6PG5 StarTech.com 10 ft Transparent USB 2.0 Cable - A to B In Stock £1.89
6PG5 StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.86
6PG5 StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £192.74
6PG5 StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.18
6PG5 StarTech.com 6 ft Transparent USB 2.0 Cable - A to B In Stock £3.64
6PG5 StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.04
6PG5 StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.30
Connectivity: KVM
Ports: 2
Price Range Ex VAT: 100 - 150
