Share a keyboard, mouse and HDMI monitor between 2 multimedia computers. The SV231HDMIUA 2-port USB HDMI KVM switch lets you control two USB-enabled multimedia computers or devices with HDMI video interfaces, using a single peripheral set/console (USB keyboard, mouse, monitor, speakers and microphone).
A highly versatile KVM solution, the USB HDMI KVM switch features an integrated 2-port USB 2.0 hub that lets selected computers access shared high speed USB devices, eliminating the cost of duplicate USB peripheral purchases.
Ensuring high quality video capability, the HDMI KVM switch supports HD resolutions of up to 1920 x 1200. Offering genuine digital signal transmission over the cable, this switch can be used to share one HD panel between multiple HDMI sources such as Blu-Ray players, video game consoles and HD media centers.
The switch also supports audio and microphone switching functions and allows you to select connected computers, USB device hub ports and audio/mic channels either simultaneously or independently using either front-panel push-buttons or keyboard hotkeys.
- StarTech.com 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub - 1080p (1920 x 1200), Hotkey Support - Dual Port Keyboard Video Monitor Switch (SV231HDMIUA) - KVM / audio / USB switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- Built-in 2-port USB 2.0 hub
- Power
- AC 120/230 V
- 12.5 cm x 7 cm x 4 cm
- 0.8 kg
- Black
- 3-year warranty
- Designed For
- P/N: IM12D1500P, SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1200
- Status Indicators
- Port status
- 2 x USB Type B , 2 x HDMI , 2 x microphone mini-jack , 2 x audio mini-jack , 2 x USB Type A , 1 x HDMI , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x microphone mini-jack , 1 x audio mini-jack
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- FCC, RoHS
- Software Included
- Drivers & Utilities
- 12.5 cm
- 7 cm
- 4 cm
- 0.8 kg
- Limited warranty - 3 years
- Designed For
StarTech.com 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub | In Stock | £177.08 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.82 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.74 |
StarTech.com 1m USB 2.0 A to A Cable - M/M | In Stock | £4.80 |
StarTech.com 2m USB 2.0 A to A Cable - M/M | In Stock | £4.92 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.66 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display | In Stock | £554.15 |
