StarTech.com 2 Port USB HDMI Cable KVM Switch w/ Audio and Remote Switch
Quicklinx: 93WTWS00 Mfr#: SV211HDUA
Type: KVM / audio switch
Ports: 2
Connectivity: KVM
26 In Stock
£71.81 ex VAT
£86.17 inc VAT
Control two HDMI, USB equipped PCs with a single monitor, keyboard, mouse and audio peripheral set. The SV211HDUA 2-Port HDMI Cable KVM Switch with Audio and Remote Switching Control lets you control two HDMI, USB equipped PCs with a single monitor, keyboard, mouse and audio peripheral set.
To help organize your desk without sacrificing work space, this compact HDMI USB KVM features integrated cables that can be connected directly to your system, while leaving a minimal footprint. The switch features a remote push-button on a 1.5 meter (5ft) integrated cable that can be placed in an easily accessible location, as well as keyboard hot-keys, and PC or Mac compatible software for switching between systems. To eliminate the need for a bulky external power adapter and wall outlet, the HDMI KVM switch is USB-powered.
This KVM with HDMI video capability offers support for 1080p HD resolutions (up to 1920x1200) for the ability to drive a large HDMI display for applications that require high graphical output.
  • Efficient remote control operation
    The KVM switch features a remote control for toggling between connected devices, enhancing user experience and operational efficiency.
  • Versatile connectivity options
    Equipped with multiple USB ports for keyboard, mouse, and audio connections, this switch facilitates a comprehensive setup for performance.
  • Stable performance under varied conditions
    Designed to operate efficiently between 0°C and 40°C, with storage capabilities as low as -20°C and up to 60°C, ensuring reliability in environments.
StarTech.com 2 Port USB HDMI Cable KVM Switch with Audio and Remote Switch - USB Powered KVM with HDMI - Dual Port HDMI KVM Switch (SV211HDUA) - KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
KVM Users Qty
1 local user
USB powered, HDCP compliant, remote switch
2.5 cm x 6 cm x 8.8 cm
400 g
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200 / 1080p
Status Indicators
Port status
3 x HDMI , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 3 x headphones mini-jack , 3 x microphone mini-jack , 2 x keyboard (USB) / mouse (USB) Type A
2 x keyboard / mouse / video / audio cable - 85 cm , 1 x remote control cable - 1.5 m
FCC, RoHS
Software Included
Drivers & Utilities
2.5 cm
6 cm
8.8 cm
400 g
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
93WT StarTech.com 2 Port USB Keyboard Mouse Switch Cable w/ File Transfer for PC and Mac In Stock £30.10
93WT StarTech.com 2 Port USB HDMI Cable KVM Switch w/ Audio and Remote Switch In Stock £71.81
93WT StarTech.com 2 Port USB VGA Cable KVM Switch - USB Powered with Remote Switch In Stock £37.15
93WT StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display In Stock £469.52
93WT StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz In Stock £83.26
93WT StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable In Stock £91.46
Ports: 2
Connectivity: KVM
