Control two HDMI, USB equipped PCs with a single monitor, keyboard, mouse and audio peripheral set. The SV211HDUA 2-Port HDMI Cable KVM Switch with Audio and Remote Switching Control lets you control two HDMI, USB equipped PCs with a single monitor, keyboard, mouse and audio peripheral set.
To help organize your desk without sacrificing work space, this compact HDMI USB KVM features integrated cables that can be connected directly to your system, while leaving a minimal footprint. The switch features a remote push-button on a 1.5 meter (5ft) integrated cable that can be placed in an easily accessible location, as well as keyboard hot-keys, and PC or Mac compatible software for switching between systems. To eliminate the need for a bulky external power adapter and wall outlet, the HDMI KVM switch is USB-powered.
This KVM with HDMI video capability offers support for 1080p HD resolutions (up to 1920x1200) for the ability to drive a large HDMI display for applications that require high graphical output.
Efficient remote control operation
The KVM switch features a remote control for toggling between connected devices, enhancing user experience and operational efficiency. -
Versatile connectivity options
Equipped with multiple USB ports for keyboard, mouse, and audio connections, this switch facilitates a comprehensive setup for performance. -
Stable performance under varied conditions
Designed to operate efficiently between 0°C and 40°C, with storage capabilities as low as -20°C and up to 60°C, ensuring reliability in environments.
 - StarTech.com 2 Port USB HDMI Cable KVM Switch with Audio and Remote Switch - USB Powered KVM with HDMI - Dual Port HDMI KVM Switch (SV211HDUA) - KVM / audio switch - 2 ports
- Subtype
 - KVM
- Ports
 - 2 x KVM / audio
- KVM Users Qty
 - 1 local user
 - USB powered, HDCP compliant, remote switch
 - 2.5 cm x 6 cm x 8.8 cm
 - 400 g
 - Black
- System Requirements
 - Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019
 - 2-year warranty
- Enclosure Type
 - Desktop
- Subtype
 - KVM
- Ports
 - 2 x KVM / audio
- KVM Local Users Qty
 - 1 local user
- Keyboard / Mouse Interface
 - USB
- Max Resolution
 - 1920 x 1200 / 1080p
- Status Indicators
 - Port status
 - 3 x HDMI , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 3 x headphones mini-jack , 3 x microphone mini-jack , 2 x keyboard (USB) / mouse (USB) Type A
 - Black
- Cables Included
 - 2 x keyboard / mouse / video / audio cable - 85 cm , 1 x remote control cable - 1.5 m
 - FCC, RoHS
- Software Included
 - Drivers & Utilities
- OS Required
 - 2.5 cm
 - 6 cm
 - 8.8 cm
 - 400 g
 - Limited warranty - 2 years
 - 0 °C
 - 40 °C
 - 0 - 90% (non-condensing)
- Min Storage Temperature
 - -20 °C
- Max Storage Temperature
 - 60 °C
                        StarTech.com 2 Port USB Keyboard Mouse Switch Cable w/ File Transfer for PC and Mac | In Stock | £9.56 |
                        StarTech.com 2 Port USB HDMI Cable KVM Switch w/ Audio and Remote Switch | In Stock | £72.95 |
                        StarTech.com 2 Port USB VGA Cable KVM Switch - USB Powered with Remote Switch | In Stock | £37.15 |
                        StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display | In Stock | £469.52 |
                        StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz | In Stock | £83.26 |
                        StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable | In Stock | £91.46 |
