Control 2 DVI, USB-equipped PCs with a single peripheral set, with USB Dynamic Device Mapping to avoid switching lag-time.
The SV231DVIUDDM 2-Port USB DVI KVM Switch lets you control 2 DVI, USB-equipped PCs using a single peripheral set at high-definition DVI resolutions up to 1920x1200.
The included KVM cables provide a ready-out-of-the-box solution, while USB Dynamic Device Mapping (DDM) and Display Data Channel (DDC) features work to significantly reduce switching lag-time and improve overall compatibility with your connected display and input devices, saving you time and money.
For the next level in KVM performance, this DVI KVM switch integrates dual-core dedicated processing per channel and innovative, USB DDM technology that enables you to quickly switch between connected computers with next-to-zero delay. DDM maintains a constant communication channel between your USB peripherals and connected systems, avoiding the time necessary for your systems to re-recognize the devices when switching.
In addition to faster switching, the KVM offers All-time Display Data Channel (Full DDC) technology to maintain proper display detection among connected systems, a simple one-touch button for hot-key selection and an integrated 2-port USB hub allowing you to share additional peripherals.
- StarTech.com 2 Port USB DVI KVM Switch with DDM Fast Switching Technology and Cables - Dual Port DVI USB KVM Switch - DDM KVM Switch (SV231DVIUDDM) - KVM / USB switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / USB
- KVM Users Qty
- 1 local user
- Power
- AC 120/230 V
- 7.6 cm x 16.5 cm x 4.4 cm
- 530 g
- Black
- Localisation
- North America, United Kingdom, Europe
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM / USB
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1440
- 2 x VGA HD-15 , 2 x keyboard (USB) / mouse (USB) Type A , 1 x VGA HD-15 , 2 x USB Type B , 1 x USB Type A , 1 x RJ-45
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- FCC, RoHS
- Localisation
- 7.6 cm
- 16.5 cm
- 4.4 cm
- 530 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 0 - 80% (non-condensing)
- Min Storage Temperature
- -30 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £269.04 |
StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £197.20 |
StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub | In Stock | £141.16 |
StarTech.com 2 Port High Resolution USB DVI Dual Link KVM Switch with Audio | In Stock | £204.94 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.75 |
