StarTech.com 2 Port USB DVI KVM Switch with DDM Fast Switching Technology and Cables
Quicklinx: 95QZWS00 Mfr#: SV231DVIUDDM
Control 2 DVI, USB-equipped PCs with a single peripheral set, with USB Dynamic Device Mapping to avoid switching lag-time.
The SV231DVIUDDM 2-Port USB DVI KVM Switch lets you control 2 DVI, USB-equipped PCs using a single peripheral set at high-definition DVI resolutions up to 1920x1200.
The included KVM cables provide a ready-out-of-the-box solution, while USB Dynamic Device Mapping (DDM) and Display Data Channel (DDC) features work to significantly reduce switching lag-time and improve overall compatibility with your connected display and input devices, saving you time and money.
For the next level in KVM performance, this DVI KVM switch integrates dual-core dedicated processing per channel and innovative, USB DDM technology that enables you to quickly switch between connected computers with next-to-zero delay. DDM maintains a constant communication channel between your USB peripherals and connected systems, avoiding the time necessary for your systems to re-recognize the devices when switching.
In addition to faster switching, the KVM offers All-time Display Data Channel (Full DDC) technology to maintain proper display detection among connected systems, a simple one-touch button for hot-key selection and an integrated 2-port USB hub allowing you to share additional peripherals.
StarTech.com 2 Port USB DVI KVM Switch with DDM Fast Switching Technology and Cables - Dual Port DVI USB KVM Switch - DDM KVM Switch (SV231DVIUDDM) - KVM / USB switch - 2 ports
Subtype
KVM
Ports
2 x KVM / USB
KVM Users Qty
1 local user
AC 120/230 V
7.6 cm x 16.5 cm x 4.4 cm
530 g
North America, United Kingdom, Europe
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / USB
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
2 x VGA HD-15 , 2 x keyboard (USB) / mouse (USB) Type A , 1 x VGA HD-15 , 2 x USB Type B , 1 x USB Type A , 1 x RJ-45
External power adapter
AC 120/230 V
FCC, RoHS
7.6 cm
16.5 cm
4.4 cm
530 g
60 °C
0 - 80% (non-condensing)
Min Storage Temperature
-30 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95QZ StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £239.06
95QZ StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £249.28
95QZ StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £115.43
95QZ StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £131.32
95QZ StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub In Stock £128.47
95QZ StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
