StarTech.com 2 Port USB C KVM Switch
Quicklinx: FX34WS00 Mfr#: SV211HDUC
Type: KVM
Ports: 2
£85.71 ex VAT
£102.85 inc VAT
This 2-port USB-C KVM enables you to easily switch between two USB Type-C or Thunderbolt 3 desktop or laptop computers, using a single keyboard, HDMI monitor and mouse.
  • Easy to setup and use
    Utilizing USB-C with DP alt-mode, this compact KVM switch only requires a single cable be connected to each of your computers, ensuring a small footprint with limited cabling requirements. All required cables for connecting your computers are included, to ensure a hassle-free setup right out of the box. For easy operation, the KVM features a single button that toggles between connected computers.
  • Supports high resolutions
    The USB-C KVM switch supports high resolutions and can drive one large HDMI 2.0 display with ease, maximizing viewing space.
  • Compact and portable
    Along with the USB-C design that ensures cabling requires are minimum the KVM is bus powered further reducing clutter by avoiding the need for a bulky power adapter. The lightweight small form factor makes this mini KVM switch easy to deploy and is ideal for mobile/hot desk workforces.
StarTech.com 2 Port USB C KVM Switch, 4K 60Hz HDMI, Compact Dual Port UHD USB Type C Desktop Mini KVM Switch with USB C Cables, Bus Powered, MacBook iPad Pro ThinkPad IdeaPad EliteBook - 4K HDMI KVM Switch - KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
USB powered, 7.1 channel audio support
14 cm x 7.2 cm x 1.6 cm
265 g
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
Status Indicators
Port status
2 x USB-C , 1 x HDMI output , 2 x USB 2.0 input Type A console
2 x USB-C cable - 1 m
MTBF
50,000 hours
RoHS, WEEE, REACH, DisplayPort 1.2
14 cm
7.2 cm
1.6 cm
265 g
Shipping Width
17.2 cm
Shipping Depth
12 cm
Shipping Height
8.5 cm
Shipping Weight
600 g
5 °C
35 °C
20 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
50 °C
FX34 StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.54
FX34 StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £22.81
FX34 StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops In Stock £6.71
FX34 StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.20
FX34 StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.31
FX34 StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £25.63
FX34 StarTech.com 1m USB C Cable - USB 3.0 In Stock £11.26
FX34 StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £12.46
FX34 StarTech.com 1.8m USB 3.1 5Gbps with PD (5A) C to C Cable - M/M Certified In Stock £24.69
FX34 StarTech.com 2 Port Hybrid USB-C KVM Switch In Stock £37.12
FX34 StarTech.com USB-C KVM Switch, 4K 60Hz In Stock £146.60
Type: KVM
Ports: 2
