This USB Type-C KVM Switch enables users to switch between two USB-C laptops, sharing a 4K 60Hz DisplayPort monitor, keyboard, mouse, and audio input/output devices.
Hassle-Free Setup
The KVM switch is bus powered and features built-in USB-C and 3.5mm Audio Input/Output cables. This ensures compatibility and performance between the KVM switch, monitor, and peripherals - without the need to select and purchase the cables required for those connections. -
Compatibility
The 2-port KVM switch is compatible with all operating systems, including Windows, macOS, ChromeOS, and Linux. The KVM works with all hardware platforms including Intel, AMD, and Apple M1/M2. -
Intuitive Control
The KVM switch offers two options to switch between hosts - a remote push-button or hotkey commands, using the downloadable software. The remote push button includes a 1.5m cable for optimal placement in the setup. Independent audio switching can be achieved through the software, utilizing keyboard shortcuts (i.e., hotkeys), ensuring uninterrupted audio when switching between host devices. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: • Advanced Windows Layout Utility: Setup and save custom windows layouts. • MAC Address Pass-Through Utility: Improve network security. • USB Event Monitoring Utility: Track and log connected USB devices. • Wi-Fi Auto Switch Utility: Enable users to quickly access faster network speeds via wired LAN.
- StarTech.com 2-Port USB-C Cable KVM Switch, 4K 60Hz DisplayPort Output, Compact KVM with 4ft/1.2m USB Type-C/Audio Integrated Cables, Bus Powered - Remote Push-Button/Hotkey Switching (C2-D46-UC2-CBL-KVM) - KVM / audio switch - compact - 2 ports
- KVM / audio switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- KVM Users Qty
- 1 local user
- USB powered, remote switch, DisplayPort Alternate mode
- 9.7 cm x 8.3 cm x 2.5 cm
- 350 g
- Black
- System Requirements
- Google Chrome OS, Apple macOS 10.12 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2160 @ 60 Hz
- USB powered, remote switch, DisplayPort Alternate mode, Auto Scan mode
- Status Indicators
- Port status
- 1 x DisplayPort output , 2 x USB 2.0 Type A , 1 x microphone output mini-jack , 1 x audio output mini-jack , 2 x audio input mini-jack , 2 x USB input Type C
- Black
- Cables Included
- 2 x USB-C cable - 1.2 m , 2 x audio cable - 1.2 m , 1 x remote control cable - 1.5 m
- MTBF
- 230,568 hours
- RoHS, WEEE, DisplayPort 1.2
- OS Required
- 9.7 cm
- 8.3 cm
- 2.5 cm
- 350 g
- Shipping Width
- 21 cm
- Shipping Depth
- 16 cm
- Shipping Height
- 6 cm
- Shipping Weight
- 420 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90% RH (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
StarTech.com 3ft DisplayPort 1.4 8K 60Hz | In Stock | £14.23 |
StarTech.com 6ft DisplayPort 1.4 8K 60Hz | In Stock | £15.57 |
StarTech.com 10ft DisplayPort 1.4 8K 60Hz | In Stock | £30.05 |
StarTech.com 2-Port Dual Monitor KVM Switch | In Stock | £161.16 |
StarTech.com 2-Port Hybrid Cable KVM Switch | In Stock | £104.47 |
StarTech.com 2-Port Dual-Monitor KVM Switch | In Stock | £207.31 |
StarTech.com 2-Port Hybrid Cable KVM Switch | In Stock | £94.61 |
