StarTech.com 2-Port USB-C Cable KVM Switch
Quicklinx: HDG4WS00 Mfr#: C2-D46-UC2-CBL-KVM
£86.51 ex VAT
£103.81 inc VAT
This USB Type-C KVM Switch enables users to switch between two USB-C laptops, sharing a 4K 60Hz DisplayPort monitor, keyboard, mouse, and audio input/output devices.
  • Hassle-Free Setup
    The KVM switch is bus powered and features built-in USB-C and 3.5mm Audio Input/Output cables. This ensures compatibility and performance between the KVM switch, monitor, and peripherals - without the need to select and purchase the cables required for those connections.
  • Compatibility
    The 2-port KVM switch is compatible with all operating systems, including Windows, macOS, ChromeOS, and Linux. The KVM works with all hardware platforms including Intel, AMD, and Apple M1/M2.
  • Intuitive Control
    The KVM switch offers two options to switch between hosts - a remote push-button or hotkey commands, using the downloadable software. The remote push button includes a 1.5m cable for optimal placement in the setup. Independent audio switching can be achieved through the software, utilizing keyboard shortcuts (i.e., hotkeys), ensuring uninterrupted audio when switching between host devices.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: • Advanced Windows Layout Utility: Setup and save custom windows layouts. • MAC Address Pass-Through Utility: Improve network security. • USB Event Monitoring Utility: Track and log connected USB devices. • Wi-Fi Auto Switch Utility: Enable users to quickly access faster network speeds via wired LAN.
StarTech.com 2-Port USB-C Cable KVM Switch, 4K 60Hz DisplayPort Output, Compact KVM with 4ft/1.2m USB Type-C/Audio Integrated Cables, Bus Powered - Remote Push-Button/Hotkey Switching (C2-D46-UC2-CBL-KVM) - KVM / audio switch - compact - 2 ports
KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
KVM Users Qty
1 local user
USB powered, remote switch, DisplayPort Alternate mode
9.7 cm x 8.3 cm x 2.5 cm
350 g
Google Chrome OS, Apple macOS 10.12 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
USB powered, remote switch, DisplayPort Alternate mode, Auto Scan mode
Status Indicators
Port status
1 x DisplayPort output , 2 x USB 2.0 Type A , 1 x microphone output mini-jack , 1 x audio output mini-jack , 2 x audio input mini-jack , 2 x USB input Type C
2 x USB-C cable - 1.2 m , 2 x audio cable - 1.2 m , 1 x remote control cable - 1.5 m
MTBF
230,568 hours
RoHS, WEEE, DisplayPort 1.2
9.7 cm
8.3 cm
2.5 cm
350 g
Shipping Width
21 cm
Shipping Depth
16 cm
Shipping Height
6 cm
Shipping Weight
420 g
0 - 90% RH (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
HDG4 StarTech.com 3ft DisplayPort 1.4 8K 60Hz In Stock £14.26
HDG4 StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £14.98
HDG4 StarTech.com 10ft DisplayPort 1.4 8K 60Hz In Stock £20.57
HDG4 StarTech.com 2-Port Dual Monitor KVM Switch In Stock £154.39
HDG4 StarTech.com 2-Port Hybrid Cable KVM Switch In Stock £99.99
HDG4 StarTech.com 2-Port Dual-Monitor KVM Switch In Stock £198.28
HDG4 StarTech.com 2-Port Hybrid Cable KVM Switch In Stock £90.64
