Add two external USB 2.0 ports to your small form factor PC. The USBPLATELP 2 Port Low Profile USB Bracket converts the USB pins on a USB 2.0 motherboard header to 2 standard USB A ports.
An ideal solution for small form factor computer cases, the slot plate can be mounted on the rear panel of your low profile or thin client computer case - adding two USB female ports for simple connection to USB peripheral devices.
- StarTech.com 2 Port USB A Female Low Profile Slot Plate Adapter - 2 Port USB Bracket - USB 2.0 A Female (USBPLATELP) - USB panel - USB to 5 pin in-line
- USB panel
- Connector
- 2 x 4 pin USB Type A - female
- Connector (Second End)
- 2 x 5 pin in-line - female
- Limited lifetime warranty
- USB panel
- Connector
StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter | In Stock | £18.52 |
StarTech.com 4 Port USB A Female Slot Plate Adapter | In Stock | £7.47 |
