StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable
Quicklinx: FLYYWS00 Mfr#: SV211DPUA4K
Type: KVM / audio switch
Ports: 2
Connectivity: KVM
More than 50 In Stock
£95.65 ex VAT
£114.78 inc VAT
The SV211DPUA4K 2-Port 4K60Hz DisplayPort Cable KVM Switch with Audio and Remote Switching Control gives you control of two DisplayPort, USB equipped computers with a single monitor, keyboard, mouse and audio peripheral set.
The DisplayPort KVM switch supports resolutions up to 4K at 60Hz and can drive one large DP display with ease, maximizing viewing space. With support for separate 3.5 mm stereo audio, the KVM switch delivers full audio compatibility across connected computers.
While supporting most PC operating systems, this DP KVM switch is OS independent which means it works with Mac computers (an adapter may be required) and any other laptops, notebooks, and tablets.
The switch features a remote push-button on a 1.5 meter (4ft) integrated cable that can be placed in an easily accessible location, as well as keyboard hot-keys, and PC or Mac compatible software for switching between systems.
StarTech.com offers a wide selection of high-quality KVM switches and KVM-related products to help you access your systems more efficiently without the expense and clutter of extra keyboards, mice and monitors.
StarTech.com 2 Port DisplayPort KVM Switch, 4K 60Hz, Compact Dual Port UHD DP 1.2 USB Desktop KVM Switch w/ Integrated 4ft Cables & Audio, Bus Powered & Remote Switching, MacBook ThinkPad - 4K KVM Switch w/ Audio (SV211DPUA4K) - KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
USB powered
8.22 cm x 9.7 cm x 0.9 cm
350 g
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160
USB powered
Status Indicators
Port status
2 x DisplayPort output , 1 x DisplayPort input , 4 x audio output mini-jack , 2 x USB 2.0 input Type A , 2 x USB 2.0 output Type A , 2 x audio input mini-jack
Keyboard / mouse / video / audio cable - 1.2 m
MTBF
1,012,884 hours
FCC, RoHS, WEEE, REACH, DisplayPort 1.2
8.22 cm
9.7 cm
0.9 cm
350 g
Shipping Width
16 cm
Shipping Depth
21 cm
Shipping Height
6 cm
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
FLYY StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F In Stock £4.98
FLYY StarTech.com 12 ft PC Speaker Extension Audio Cable In Stock £5.05
FLYY StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.06
FLYY StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F In Stock £5.91
FLYY StarTech.com 1m Slim 3.5mm Stereo Extension Audio Cable - M/F In Stock £5.46
FLYY StarTech.com 1m 3.5mm 4 Position TRRS Headset Extension Cable - M/F In Stock £5.45
FLYY StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.67
FLYY StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.57
FLYY StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable In Stock £95.65
FLYY StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.12
FLYY StarTech.com 2 Port USB C KVM Switch In Stock £90.34
FLYY StarTech.com 2 Port Triple Monitor DisplayPort KVM Switch In Stock £370.86
FLYY StarTech.com 2 Port Quad Monitor DisplayPort KVM Switch In Stock £537.92
FLYY StarTech.com 2 Port Hybrid USB-C KVM Switch In Stock £95.09
Ports: 2
Connectivity: KVM
