The SV211DPUA4K 2-Port 4K60Hz DisplayPort Cable KVM Switch with Audio and Remote Switching Control gives you control of two DisplayPort, USB equipped computers with a single monitor, keyboard, mouse and audio peripheral set.
The DisplayPort KVM switch supports resolutions up to 4K at 60Hz and can drive one large DP display with ease, maximizing viewing space. With support for separate 3.5 mm stereo audio, the KVM switch delivers full audio compatibility across connected computers.
While supporting most PC operating systems, this DP KVM switch is OS independent which means it works with Mac computers (an adapter may be required) and any other laptops, notebooks, and tablets.
The switch features a remote push-button on a 1.5 meter (4ft) integrated cable that can be placed in an easily accessible location, as well as keyboard hot-keys, and PC or Mac compatible software for switching between systems.
StarTech.com offers a wide selection of high-quality KVM switches and KVM-related products to help you access your systems more efficiently without the expense and clutter of extra keyboards, mice and monitors.
High-resolution support
The KVM switch supports resolutions up to 3840 x 2160, allowing for sharp and detailed video output suitable for professional applications. -
Multiple connectivity options
Equipped with USB 2.0 inputs and outputs, along with audio input and output, this switch accommodates various devices for a versatile workspace. -
Environmental resilience
This KVM switch operates efficiently within a temperature range of 0 °C to 40 °C, along with storage capabilities from -20 °C to 60 °C, ensuring adaptability in different environments. -
Long operational lifespan
With an MTBF of 1,012,884 hours, users can rely on the KVM switch for consistent performance and durability over time. -
Easy installation
The USB-powered design allows for a straightforward setup, enabling users to connect the switch and start using it quickly without extensive configuration.
- StarTech.com 2 Port DisplayPort KVM Switch, 4K 60Hz, Compact Dual Port UHD DP 1.2 USB Desktop KVM Switch w/ Integrated 4ft Cables & Audio, Bus Powered & Remote Switching, MacBook ThinkPad - 4K KVM Switch w/ Audio (SV211DPUA4K) - KVM / audio switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- USB powered
- 8.22 cm x 9.7 cm x 0.9 cm
- 350 g
- Black
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2160
- USB powered
- Status Indicators
- Port status
- 2 x DisplayPort output , 1 x DisplayPort input , 4 x audio output mini-jack , 2 x USB 2.0 input Type A , 2 x USB 2.0 output Type A , 2 x audio input mini-jack
- Black
- Cables Included
- Keyboard / mouse / video / audio cable - 1.2 m
- MTBF
- 1,012,884 hours
- FCC, RoHS, WEEE, REACH, DisplayPort 1.2
- OS Required
- 8.22 cm
- 9.7 cm
- 0.9 cm
- 350 g
- Shipping Width
- 16 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 6 cm
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F | In Stock | £4.89 |
StarTech.com 12 ft PC Speaker Extension Audio Cable | In Stock | £5.37 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.58 |
StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F | In Stock | £6.20 |
StarTech.com 1m Slim 3.5mm Stereo Extension Audio Cable - M/F | In Stock | £2.65 |
StarTech.com 1m 3.5mm 4 Position TRRS Headset Extension Cable - M/F | In Stock | £5.53 |
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.71 |
StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £7.11 |
StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable | In Stock | £93.76 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £13.72 |
StarTech.com 2 Port USB C KVM Switch | In Stock | £77.13 |
StarTech.com 2 Port Triple Monitor DisplayPort KVM Switch | In Stock | £360.65 |
StarTech.com 2 Port Quad Monitor DisplayPort KVM Switch | In Stock | £461.44 |
StarTech.com 2 Port Hybrid USB-C KVM Switch | In Stock | £32.88 |
