StarTech.com 2-Port USB 3.2 Gen 2 PCIe Card - USB-A SuperSpeed 10Gbps PCI Express 3.0 x2
Quicklinx: G59WWS00 Mfr#: PEXUSB312A3
Type: USB adapter
Compatibility: PC
Interface: PCI Express 3.0 x4
£24.39 ex VAT
£29.26 inc VAT
USB 3.2 Gen 2 (10 Gbps) PCI-Express 3.0 PCIe x2 Slot USB Type-A. This PCIe USB 3.2 Gen 2 controller card installs into an available PCI-Express x4 slot in your computer and enables you to upgrade your current system by adding two SuperSpeed USB-A (10Gbps) ports.
Add two 10 Gbps USB Type-A Ports to Your Desktop Computer
The controller card enables you to connect two USB-A Gen 2 (10 Gbps) devices to your desktop computer. The USB-A ports are ideal for connecting USB devices such as external hard drives and solid state drives or powering and syncing your mobile devices. The USB-A ports provides up to 4.5W (5V/0.9A) of power per USB port, and are backward compatible with USB 3.2 Gen 1 (5 Gbps), and USB 2.0 (480 Mbsp) devices.
Note: USB 3.2 Gen 2 (10 Gbps) is also know as USB 3.1 Gen 2 (10 Gbps), and USB 3.2 Gen 1 (5 Gbps) is also know as USB 3.0 and USB 3.1 (5 Gbps).
SuperSpeed USB 3.2 Gen 2 (10 Gbps) Performance
The USB 3.2 Gen 2 card features an ASMedia ASM3142 host controller that utilizes x2 lanes of the PCIe 3.0 bus, making the card capable of speeds up to 10Gbps on each port, and enabling fast access to high-performance devices like NVMe drives and SSDs. The controller card supports Multiple INs to reduce bandwidth loss when multiple devices are connected, even when connected through a USB Hub (Note: The USB hub must also support this feature). The card also supports UASP for improved performance with storage devices.
Wide Installation Compatibility
This add-on card includes both full-profile and low-profile installation brackets ensuring you can install it into either a full or low-profile PCIe 3.0 x4 slot (backward compatible w/PCIe 2.0). For wide platform support the card is compatible with Windows, Linux and macOS. For hassle-free installation the drivers install automatically on computers running Windows 8 or higher. Works w/USB 3.1/3.0/2.0 devices
PEXUSB312A3 is backed by a StarTech.com lifetime warranty with free 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
  • Add two 10 Gbps USB Type-A Ports to Your Desktop Computer
    The controller card enables you to connect two USB-A Gen 2 (10 Gbps) devices to your desktop computer. The USB-A ports are ideal for connecting USB devices such as external hard drives and solid state drives or powering and syncing your mobile devices. The USB-A ports provides up to 4.5W (5V/0.9A) of power per USB port, and are backward compatible with USB 3.2 Gen 1 (5 Gbps), and USB 2.0 (480 Mbsp) devices. Note: USB 3.2 Gen 2 (10 Gbps) is also know as USB 3.2 Gen 2 (10 Gbps), and USB 3.2 Gen 1 (5 Gbps) is also know as USB 3.2 Gen 1 and USB 3.2 (5 Gbps).
  • SuperSpeed USB 3.2 Gen 2 (10 Gbps) Performance
  • Wide Installation Compatibility
    This add-on card includes both full-profile and low-profile installation brackets ensuring you can install it into either a full or low-profile PCIe 3.0 x4 slot (backward compatible w/PCIe 2.0). For wide platform support the card is compatible with Windows, Linux and macOS. For hassle-free installation the drivers install automatically on computers running Windows 8 or higher. Works w/USB 3.2/3.0/2.0 devices PEXUSB312A3 is backed by a StarTech.com lifetime warranty with free 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
StarTech.com 2-Port USB PCIe Card 10Gbps/port - USB 3.1/3.2 Gen 2 Type-A PCI Express 3.0 x2 Host Controller Expansion Card - Windows/Linux - USB adapter - PCIe 3.0 x4 - USB-C 3.1 Gen 2 x 2 - TAA Compliant
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 3.0 x4
Ports
USB-C 3.1 Gen 2 x 2
1.8 cm x 9 cm x 12 cm
50 g
USB, USB 2.0, USB 3.0, USB 3.1
Data Transfer Rate
10 Gbps
ASMedia ASM1142
USB 1.1, USB 2.0, USB 3.0, xHCI, USB 3.1 Gen 2
Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Linux 3.5 or later, Apple macOS 10.13 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
TAA Compliant
USB adapter
PCI Express 3.0 x4
Ports
USB-C 3.1 Gen 2 x 2
Wired
USB, USB 2.0, SuperSpeed USB 3.0, USB 3.1
Data Transfer Rate
10 Gbps
UASP
Processor / Memory
ASMedia ASM1142
2 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x SATA power - 15 pin Serial ATA power (internal)
Low-profile bracket
MTBF
50,000 hours
FCC, RoHS, WEEE, UASP (USB Attached SCSI Protocol)
TAA Compliant
1.8 cm
9 cm
12 cm
50 g
Shipping Width
13 cm
Shipping Depth
16 cm
Shipping Height
3 cm
Shipping Weight
100 g
70 °C
5 - 95% (non-condensing)
G59W StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
G59W StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £7.61
G59W StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £9.41
G59W StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £11.00
G59W StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.45
G59W StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £62.29
G59W StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £26.43
G59W StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
G59W StarTech.com 3ft Slim Micro USB 3.0 Cable In Stock £9.00
G59W StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black In Stock £8.64
G59W StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 In Stock £38.05
G59W StarTech.com 4-Port USB 3.2 Gen 2 PCIe Card - USB-A SuperSpeed 10Gbps PCI Express 3.0 x4 In Stock £87.44
G59W StarTech.com 1-Port USB 3.2 Gen 2x2 PCIe Card - USB-C SuperSpeed 20Gbps PCI Express 3.0 x4 In Stock £40.64
G59W StarTech.com 4-Port USB PCIe Card In Stock £101.62
G59W StarTech.com 5-Port USB PCIe Card, 10Gbps In Stock £57.55
G59W StarTech.com 4-Port USB-A PCIe Card, 5Gbps In Stock £80.54
G59W StarTech.com 4-Port USB-C 10Gb PCIe Card In Stock £201.91
G59W StarTech.com 4-Port USB-C 10Gb PCIe Card In Stock £206.78
Type: USB adapter
Compatibility: PC
