StarTech.com 2 Port USB 3.1 Card - 2x A
Quicklinx: CZCFWS00 Mfr#: PEXUSB312A2
Add two 10Gbps USB Type-A ports to your computer, through a PCI Express slot. This USB 3.1 card lets you add two USB Type-A ports to your computer, through a PCI Express slot. It enables you to upgrade your current system by adding two USB 3.1 Gen 2 ports to your computer and giving you access to data transfer speeds up to 10Gbps.
By adding 10Gbps USB ports to your computer, you can harness the speed of USB 3.1 Gen 2 and rest assured you're ready for both current and future high-bandwidth USB-A devices.
With higher data throughput support, this PCI Express USB 3.1 card is a necessity for external drives, drive enclosures, and many other USB 3.1 peripherals. Plus, the USB card includes an optional SATA power connector to connect to your system power supply and deliver up to 900mA of power per port to USB 3.1 bus-powered devices (500mA for USB 2.0). The card is ideal for use with large external storage solutions.
Connecting older peripherals isn't a problem. This versatile dual-port USB 3.1 card is backward compatible with legacy USB 3.0/2.0 devices that use the common USB Type-A port, so you can eliminate the added expense and aggravation of purchasing new devices.
The USB 3.1 PCIe card is compatible with a broad range of Windows and Linux operating systems. Plus, the high-quality card includes both standard-profile and low-profile brackets, making it easy to install in full or small form-factor PCs and servers.
StarTech.com 2-Port USB PCIe Card - 10Gbps USB 3.1 Gen 2 Type-A PCI Express Host Controller Expansion Card (PEXUSB312A2) - USB adapter - PCIe 3.0 x4 - USB 3.1 Gen 2 x 2
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 3.0 x4
Ports
USB 3.1 Gen 2 x 2
1.08 cm x 12.2 cm x 2.1 cm
50 g
USB, USB 2.0, USB 3.0, USB 3.1
Data Transfer Rate
10 Gbps
ASMedia ASM2142
xHCI
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 3.5 to 4.4.x LTS versions
P/N: SDOCK4U313
USB adapter
PCI Express 3.0 x4
Ports
USB 3.1 Gen 2 x 2
Wired
USB, USB 2.0, SuperSpeed USB 3.0, USB 3.1
Data Transfer Rate
10 Gbps
xHCI
Processor / Memory
ASMedia ASM2142
2 x USB 3.1 - 9 pin USB Type A , 1 x SATA power - 15 pin Serial ATA power (internal)
Low-profile bracket
FCC, RoHS, UASP (USB Attached SCSI Protocol)
1.08 cm
12.2 cm
2.1 cm
50 g
Limited warranty - lifetime
5 °C
50 °C
20 - 80%
P/N: SDOCK4U313
CZCF StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
CZCF StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £81.81
CZCF StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £11.00
CZCF StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.45
CZCF StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £62.29
CZCF StarTech.com 7 Port PCIe USB 3.0 Card In Stock £56.73
CZCF StarTech.com 4 Port PCIe USB 3.0 Card In Stock £27.19
CZCF StarTech.com 4 Port PCIe USB 3.0 Card In Stock £23.79
CZCF StarTech.com 3 Port PCIe USB 3.0 Card + GbE In Stock £42.00
CZCF StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £26.43
CZCF StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
