Extend two USB 2.0 connections with power, by up to 330ft over Cat5 or Cat6 cable. The USB2002EXT2 2-Port USB Extender lets you extend USB 2.0 devices over Cat 5 or better Ethernet cable at distances of up to 330ft (100m). A local transmitter power adapter provides up to 500 mA of power per port with no power adapter required at the remote end, letting you access and power almost any USB 2.0 device in locations where a power outlet may be unavailable.
This USB extender provides support for data transfer rates of up to 480 Mbps, is Plug-and-Play and hot-swap compatible, and is also backwards compatible with USB 1.x devices.
This versatile USB extender offers a fast, easy, and flexible solution for business or industrial applications with durable metal housing, and an included surface-mounting bracket kit.
- StarTech.com Replaced by USB2002EXT2NA - 2 Port USB 2.0 over Cat5 or Cat6 Extender Kit - Local / Remote Power - 330 ft - USB Extender (USB2002EXT2) - USB extender - USB, USB 2.0
- USB extender
- Ports Qty
- 2
- Form Factor
- External
- Data Transfer Rate
- 480 Mbps
- Data Link Protocol
- USB, USB 2.0
- Transmission Medium
- CAT 5/6
- Max Transfer Distance
- 100 m
- Power
- AC 120/230 V
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows XP 64-bit Edition, Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0
- 7.6 cm x 10 cm x 2.6 cm
- 0.6 kg
- 2-year warranty
- Designed For
- P/N: 35FCREADBK3
- USB extender
- Form Factor
- External
- Black
- Ports Qty
- 2
- Connectivity Technology
- Wired
- USB, USB 2.0
- 480 Mbps
- 100 m
- Status Indicators
- Power, link OK, link/activity
- 1 x USB 2.0 - Type A male , 2 x USB 2.0 - Type A female
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- OS Required
- 7.6 cm
- 10 cm
- 2.6 cm
- 0.6 kg
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 10 - 90%
- Designed For
- P/N: 35FCREADBK3
StarTech.com 6in Mini USB 2.0 Cable - A to Mini B | In Stock | £4.02 |
StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m) | In Stock | £104.49 |
StarTech.com 4-port USB 2.0 Over Cat5 or Cat6 Extender (50m) | In Stock | £146.84 |
