StarTech.com 2 Port Triple Monitor DisplayPort KVM Switch
Quicklinx: GGQXWS00 Mfr#: SV231TDPU34K
Type: KVM / audio switch
Ports: 2
Connectivity: KVM
Hurry, only 1 left in stock!
£351.85 ex VAT
£422.22 inc VAT
KVM with USB - Triple Monitor - TAA Compliant - USB 3.0 Hub - DisplayPort 1.2 - Digital & Analog Audio.
  • 4K 60Hz Picture and Full Audio Support
    The DisplayPort KVM switch supports resolutions up to 4K at 60Hz. It drives three large monitors at the full 4K resolution. Includes USB emulation for faster switching times to avoid disrupting your workflow. With support for digital audio (with supporting displays and sources) and separate 3.5 mm stereo audio, the DisplayPort 1.2 KVM switch delivers full audio compatibility.
  • Integrated USB Hub
    The integrated USB 3.0 hub shares two peripherals (in addition to keyboard and mouse) among attached computers as if they were directly connected to your host computer, eliminating the cost of duplicate devices such as printers and scanners.
  • Windows, Mac & Linux Compatible
    While supporting Windows, this DP KVM switch is also compatible with Mac and Linux operating systems.
  • Easy to Operate
    The front-panel pushbuttons make it easy to switch between systems and activate the auto-scan feature. The hotkey functionality makes accessing each system quickly, while a buzzer sound confirms the switch. StarTech.com?offers?a wide selection of high-quality KVM?switches?and KVM-related products to help you access your systems more efficiently without the expense and clutter of extra keyboards, mice, and monitors.?This?2-port DisplayPort KVM switch?is backed by a?2-year warranty and free lifetime technical support.
StarTech.com 2 Port Triple Monitor DisplayPort KVM Switch, 4K 60Hz UHD HDR, Desktop 4K DP 1.2 KVM with 2 Port USB 3.0 Hub (5Gbps) & 4x USB 2.0 HID Ports, Audio, Hotkey Switching, TAA - Keyboard/Video/Mouse Switch - KVM / audio switch - 2 ports - TAA Compliant
Subtype
KVM
Ports
2 x KVM / audio
5.1 channel audio support, HDR support
USB 1.1, USB 2.0, USB 3.0
AC 100-240 V
16 cm x 10 cm x 9.8 cm
Japan, New Zealand, North America, United Kingdom, Europe
TAA Compliant
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
Status Indicators
Status
3 x DisplayPort output , 6 x DisplayPort input , 2 x USB 3.0 output Type A , 2 x USB 3.0 input Type B , 4 x USB 1.1 Type A , 2 x audio input mini-jack , 1 x audio output mini-jack
External power adapter
Power Provided
DC 12 V - 3 A
AC 100-240 V
36 Watt
4 rubber feet
MTBF
156,000 hours
FCC, RoHS, DisplayPort 1.2, HDCP 2.2
TAA Compliant
16 cm
10 cm
9.8 cm
Shipping Width
23.8 cm
Shipping Depth
18.9 cm
Shipping Height
9.1 cm
Shipping Weight
141 g
0 - 80%
Min Storage Temperature
-10 °C
Max Storage Temperature
60 °C
GGQX StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £9.86
GGQX StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £7.73
GGQX StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £6.92
GGQX StarTech.com 2m 6.6ft DisplayPort 1.4 Cable In Stock £8.49
GGQX StarTech.com 3m 9.8ft DisplayPort 1.4 Cable In Stock £17.22
GGQX StarTech.com 2 Port Dual Monitor HDMI KVM Switch In Stock £306.74
GGQX StarTech.com 2 Port HDMI KVM Switch In Stock £234.56
GGQX StarTech.com 4 Port HDMI KVM Switch In Stock £315.75
GGQX StarTech.com 2 Port Quad Monitor DisplayPort KVM Switch In Stock £457.28
GGQX StarTech.com 2-Port DP KVM Switch, 8K 60Hz In Stock £302.41
GGQX StarTech.com 4-Port DP KVM Switch, 8K 60Hz In Stock £369.44
Ports: 2
Connectivity: KVM
