KVM with USB - Triple Monitor - TAA Compliant - USB 3.0 Hub - DisplayPort 1.2 - Digital & Analog Audio.
4K 60Hz Picture and Full Audio Support
The DisplayPort KVM switch supports resolutions up to 4K at 60Hz. It drives three large monitors at the full 4K resolution. Includes USB emulation for faster switching times to avoid disrupting your workflow. With support for digital audio (with supporting displays and sources) and separate 3.5 mm stereo audio, the DisplayPort 1.2 KVM switch delivers full audio compatibility. -
Integrated USB Hub
The integrated USB 3.0 hub shares two peripherals (in addition to keyboard and mouse) among attached computers as if they were directly connected to your host computer, eliminating the cost of duplicate devices such as printers and scanners. -
Windows, Mac & Linux Compatible
While supporting Windows, this DP KVM switch is also compatible with Mac and Linux operating systems. -
Easy to Operate
The front-panel pushbuttons make it easy to switch between systems and activate the auto-scan feature. The hotkey functionality makes accessing each system quickly, while a buzzer sound confirms the switch. StarTech.com?offers?a wide selection of high-quality KVM?switches?and KVM-related products to help you access your systems more efficiently without the expense and clutter of extra keyboards, mice, and monitors.?This?2-port DisplayPort KVM switch?is backed by a?2-year warranty and free lifetime technical support.
- StarTech.com 2 Port Triple Monitor DisplayPort KVM Switch, 4K 60Hz UHD HDR, Desktop 4K DP 1.2 KVM with 2 Port USB 3.0 Hub (5Gbps) & 4x USB 2.0 HID Ports, Audio, Hotkey Switching, TAA - Keyboard/Video/Mouse Switch - KVM / audio switch - 2 ports - TAA Compliant
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- 5.1 channel audio support, HDR support
- USB 1.1, USB 2.0, USB 3.0
- Power
- AC 100-240 V
- 16 cm x 10 cm x 9.8 cm
- Black
- Localisation
- Japan, New Zealand, North America, United Kingdom, Europe
- TAA Compliant
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2160 @ 60 Hz
- Status Indicators
- Status
- 3 x DisplayPort output , 6 x DisplayPort input , 2 x USB 3.0 output Type A , 2 x USB 3.0 input Type B , 4 x USB 1.1 Type A , 2 x audio input mini-jack , 1 x audio output mini-jack
- Power Device
- External power adapter
- Power Provided
- DC 12 V - 3 A
- Voltage Required
- AC 100-240 V
- 36 Watt
- Black
- Included Accessories
- 4 rubber feet
- MTBF
- 156,000 hours
- FCC, RoHS, DisplayPort 1.2, HDCP 2.2
- TAA Compliant
- Localisation
- 16 cm
- 10 cm
- 9.8 cm
- Shipping Width
- 23.8 cm
- Shipping Depth
- 18.9 cm
- Shipping Height
- 9.1 cm
- Shipping Weight
- 141 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 60 °C
StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £9.84 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £7.61 |
StarTech.com 1m 3.3ft DisplayPort 1.4 Cable | In Stock | £6.89 |
StarTech.com 2m 6.6ft DisplayPort 1.4 Cable | In Stock | £11.86 |
StarTech.com 3m 9.8ft DisplayPort 1.4 Cable | In Stock | £23.75 |
StarTech.com 2 Port HDMI KVM Switch | In Stock | £240.42 |
StarTech.com 4 Port HDMI KVM Switch | In Stock | £323.66 |
StarTech.com 2 Port Quad Monitor DisplayPort KVM Switch | In Stock | £461.44 |
StarTech.com 2-Port DP KVM Switch, 8K 60Hz | In Stock | £305.16 |
StarTech.com 4-Port DP KVM Switch, 8K 60Hz | In Stock | £378.68 |
