StarTech.com 2-Port SFP+ OCP Network Card
Quicklinx: HVMHWS00 Mfr#: O1210I-NETWORK-CARD
£289.13 ex VAT
£346.95 inc VAT
The StarTech.com network adapter is a high-performance solution designed to meet the needs of demanding network environments. With dual 10 Gigabit SFP+ ports, it offers superior connectivity and bandwidth management. This adapter is built to perform reliably across a broad range of operational conditions, thanks to its wide operating temperature and humidity range. It supports advanced networking features such as Quality of Service (QoS), Single Root I/O Virtualization (SR-IOV), and various Ethernet standards, making it a versatile choice for any setup. Additionally, its compliance with RoHS and WEEE standards reflects a commitment to environmental sustainability. Whether upgrading an existing system or setting up a new network, this network adapter provides the features and reliability needed to support complex network architectures and demanding applications.
  • Enhanced connectivity
    Equipped with dual 10 Gigabit SFP+ ports, this network adapter ensures high-speed connectivity and better bandwidth management for demanding network environments.
  • Robust environmental adaptability
    Designed to operate efficiently across a wide range of humidity (5 - 90% RH) and temperature (0°C to 60°C), ensuring reliability and performance in various operational conditions.
  • Advanced networking features
    Supports a suite of advanced features such as Data Plane Development Kit (DPDK), Quality of Service (QoS), and Single Root I/O Virtualization (SR-IOV), enhancing network management and virtualization.
  • Comprehensive protocol support
    With support for multiple Ethernet standards and data link protocols including 10 Gigabit Ethernet, Fast Ethernet, and Gigabit Ethernet, this adapter offers versatile connectivity options for diverse network architectures.
  • Environmentally compliant
    Adheres to RoHS and WEEE standards, ensuring an environmentally friendly and sustainable solution for your networking needs.
StarTech.com - network adapter - OCP 3.0 - 10 Gigabit SFP+ x 2
Network adapter
Plug-in card
Interface (Bus) Type
Open Compute Project mezzanine (OCP) 3.0
PCI Specification Revision
PCIe 2.0, PCIe 3.0, PCIe 2.1
Ports
10 Gigabit SFP+ x 2
1.5 cm x 13.2 cm x 8.5 cm
104 g
Cabling Type
Ethernet 1000Base-LX, Ethernet 1000Base-SX, Ethernet 10GBase-LR, Ethernet 10GBase-SR, Ethernet 1000Base-EX, Ethernet 1000Base-T, Ethernet 10GBase-T, Ethernet 10GBase-CR
10Mb LAN, 100Mb LAN, 1GbE, 10GbE
Data Transfer Rate
10 Gbps
Jumbo frame size: 9000
Intel X710-BM2
IEEE 802.3, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ae, IEEE 802.1ad, IEEE 1588-2008, OCP 3.0, SFF-TA-1002
Linux 2.6.x or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Microsoft Windows Server 2022, Microsoft Windows 10 / 11
Network adapter
Plug-in card
Ports
10 Gigabit SFP+ x 2
Wired
Cabling Type
Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Status Indicators
Link/activity/speed
Full duplex capability, VLAN support, WOL, QoS, VMDq, SR-IOV, PTP, NVGRE, Link Aggregation, DPDK, Q-in-Q tunnelling, bridge mode, promiscuous mode, GENEVE support, hot swappable, DDP, PXE boot, bus powered, VxLAN-GPE with NSH, Enhanced NVO
Processor / Memory
Intel X710-BM2
1 x 10Gb Ethernet - SFP+
RoHS, WEEE
1.5 cm
13.2 cm
8.5 cm
104 g
Shipping Width
3 cm
Shipping Depth
17 cm
Shipping Height
14.2 cm
Shipping Weight
106 g
60 °C
5 - 90% RH
HVMH StarTech.com 3m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £48.36
HVMH StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m In Stock £37.05
