StarTech.com 2 Port SATA to eSATA Slot Plate Bracket
Quicklinx: 5CCLWS00 Mfr#: ESATAPLATE2
Turn two standard SATA motherboard connections into two external eSATA ports. StarTech.com's eSATA SATA adapter plate adds external data support to any existing Serial ATA controller, adding two eSATA ports for connection to external SATA devices.
The adapter plate can be mounted to the rear panel of the computer case, providing straightforward eSATA to SATA connections and allowing users to connect their eSATA device (hard drive enclosure, etc.) to the provided eSATA port which is an extension of the motherboard SATA data connector.
Designed to take advantage of the increased data integrity provided by external hard drives or RAID devices that support eSATA connections, the eSATA SATA adapter supports data transfer rates of up to 6Gbps.
StarTech.com 2 Port SATA to eSATA Slot Plate BRacket - eSATA slot bRacket - SATA to eSATA plate - SATA to eSATA bRacket (ESATAPLATE2) - SATA internal to external panel - 30 cm
Interface Speed
Serial ATA 150/300/600
Length
30 cm
Connector
2 x 7 pin Serial ATA - female
Connector (Second End)
2 x 7 pin external Serial ATA - male
Red
P/N: S251SMU33EP, S351BMU33ET, S351BMU33ETG, SDOCKU313E, SDOCKU33EF
Storage Cable Type
Interface Speed
Length
30 cm
Red
Connector
