StarTech.com 2 Port SATA 6 Gbps PCI Express eSATA Controller Card
Quicklinx: 76PPWS00 Mfr#: PEXESAT32
Type: Storage controller
Controller Interface: eSATA-600
Interface: PCI Express
Compatibility: PC
  • Windows 8 (32/64 bits)
17 in stock
£22.16 ex VAT
£26.59 inc VAT
The PEXESAT32 2 Port PCI Express eSATA 6Gbps Controller Card offers simple connectivity between a host computer and eSATA 3.0 devices - a cost-effective solution for connecting high-speed storage, such as High RPM Hard Drives and Solid State Drives (SSD), which in turn allows for easier data backups and archiving.
With full support for SATA 3.0 hard drives and data transfer speeds of up to 6 Gbps, the adapter card features a native PCI Express single chipset that provides enhanced compatibility, reliability and performance for external SATA 600 MB/s storage needs.
The controller card is backward compatible with SATA 2.0 devices, providing the versatility to use older storage, and features port multiplier capability with command-based and FIS-based switching for connecting multiple external hard drives to a host PC through a single external SATA connection.
A dual profile solution, the eSATA controller card includes a low profile bracket for installation in slimline or small form factor computer cases.
StarTech.com 2 Port SATA 6 Gbps PCI Express eSATA Controller Card - Storage controller - 2 Channel - eSATA 6Gb/s - 6 Gbit/s - PCIe - PEXESAT32 - storage controller - eSATA 6Gb/s - PCIe
Storage controller - plug-in card
Bus Type
PCIe
eSATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
Hard drive
Channel Qty
2
Max Storage Devices Qty
2
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
64.5 cm x 67.7 cm x 21.3 cm
67.9 g
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, S251SMU33EP, S3520BU33ER, S355BU33ERM, TB31PCIEX16
Host Bus
PCIe
Storage Controller
eSATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
Hard drive
Channel Qty
2
2
Marvell 88SE9123
2 x eSATA 6Gb/s - eSATA
Compatible Slots
1 x PCI Express
FCC, RoHS
Limited warranty - lifetime
64.5 cm
67.7 cm
21.3 cm
67.9 g
76PP StarTech.com 6 ft Shielded eSATA to SATA Cable In Stock £9.06
76PP StarTech.com 3 ft Shielded External eSATA Cable M/M In Stock £6.92
76PP StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £9.34
76PP StarTech.com 1 Port eSATA + 1 Port SATA PCI SATA Controller Card w/ LP Bracket In Stock £12.91
76PP StarTech.com 2 Port SATA 6 Gbps PCI Express SATA Controller Card In Stock £26.15
76PP StarTech.com 2 Port SATA 6 Gbps PCI Express eSATA Controller Card In Stock £22.16
Compatibility: PC
Price Range Ex VAT: 0 - 50
