This two port Ethernet-to-Remote Serial interface converter lets you install RS 232 serial devices anywhere on your TCP/IP Ethernet WAN/LAN, and your serial devices will perform as if they were right beside you - even over the Internet!
Even at the longest distances, control of your serial devices will be right at your fingertips: the remote serial ports appear alongside your local serial ports in your Windows device manager.
The Serial Ethernet IP Adapter (Device Server, Console Server) is designed to function seamlessly with your other serial ports for totally transparent operation. Your serial equipment - card scanners, access keypads, bar code scanners, and more - will operate as smoothly as if the serial ports were right inside your computer.
For industrial automation, security, Point of Sale, or any time you need reliable, long-range serial communications, this converter will deliver superior performance in any environment.
- StarTech.com 2 Port RS232 Serial over IP Ethernet Device Server - device server
- Device server
- Form Factor
- External
- Localisation
- United Kingdom
- Ports Qty
- 2
- Data Link Protocol
- Ethernet, RS-232
- OS Required
- Linux, Microsoft Windows 2000 / XP
- Limited lifetime warranty
- Device server
- Enclosure Colour
- Beige
- Localisation
- United Kingdom
- Form Factor
- External
- Ports Qty
- 2
- Connectivity Technology
- Wired
- Data Transfer Rate
- 115.2 Kbps
- Ethernet, RS-232
- TCP/IP, UDP/IP, ICMP/IP
- Remote Management Protocol
- Telnet, HTTP
- Status Indicators
- Transmit, receive
- Firmware upgradable
- 2 x RS-232 - DB-9 , 1 x 10Base-T
- UL, FCC
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities, Ether Link Manager
- OS Required
- Limited warranty - lifetime
