StarTech.com 2 Port RS232 Serial Adapter Card with 16950 UART - 921.4Kbps
Quicklinx: FBZWWS00 Mfr#: PEX2S953LP
Wired / Wireless: Wired
Protocol: RS-232
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Serial adapter
14 In Stock
£38.30 ex VAT
£45.96 inc VAT
This RS232 Serial Adapter Card lets you add two RS232 (DB9) serial ports to your computer through a PCI Express (PCIe) slot. It enables you to interact with serial devices, such as card readers, printers, PIN pads, and modems, at speeds of up to 921.4Kbps.
With broad OS support, including for Windows and Linux, this PCI Express card is easy to integrate into mixed environments. The card comes pre-configured with a low-profile bracket, and includes an optional full-profile bracket, so installation is easy regardless of the case form factor.
This PCIe to serial adapter supports the following features: Compatible with industry standard 16950 UART; Supports max baud rate of up-to 921.4Kbps; Provides 5/12V power output on Pin 9 when external power is connected; 128-byte depth FIFO per transmitter and receiver; Supports 9, 8, 7, 6, 5 data bits; Asix AX99100 chipset; PCI Express 1.1 compliant.
  • Enhanced connectivity
    This 2-port PCI Express RS232 Serial Adapter Card offers seamless connectivity with its two 9-pin D-Sub (DB-9) RS-232 ports, enabling efficient connection to a wide range of serial devices.
  • High-speed data transfer
    Experience rapid data communication with a data transfer rate of up to 921.6 Kbps, facilitated by a 256-byte FIFO and full duplex mode. This ensures swift and reliable data transmission for all connected devices.
  • Broad compatibility
    Designed to support a variety of operating systems, this PCIe to Serial DB9 COM Ports card is compatible with Windows, macOS, and Linux, offering versatile use across different platforms.
  • Durable and compliant
    Built to last, the card adheres to FCC, RoHS, WEEE, and WHQL standards, ensuring a reliable and environmentally friendly solution for expanding your system's serial capabilities.
Startech 2-port PCI Express RS232 Serial Adapter Card, PCIe RS232 Serial Host Controller Card, PCIe to Serial DB9 COM Ports, 16950 UART, Low Profile Expansion Card, Windows/macOS/Linux - Full/Low-Profile (PEX2S953LP) - serial adapter - PCI Express x1 - RS-232 x 2
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.1
Ports
RS-232 x 2
6.7 cm x 9.8 cm x 1.8 cm
55.6 g
RS-232
Data Transfer Rate
921.6 Kbps
ASIX AX99100
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux 2.4 - 2.6.x
Serial adapter
PCI Express x1
PCIe 1.1
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Full duplex mode, 256-byte FIFO
Processor / Memory
ASIX AX99100
2 x RS-232 - 9 pin D-Sub (DB-9)
Full-height bracket
WHQL, FCC, RoHS, WEEE
6.7 cm
9.8 cm
1.8 cm
55.6 g
Shipping Weight
146.4 g
Limited warranty - lifetime
-10 °C
80 °C
5 - 85%
FBZW StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.57
FBZW StarTech.com 2 Port PCI Express RS232 Serial Adapter Card In Stock £36.05
FBZW StarTech.com PCIe Card with Serial and Parallel Port - PCI Express Combo In Stock £33.98
FBZW StarTech.com Serial/Parallel PCI Card In Stock £20.41
Protocol: RS-232
