This two-port KVM switch combines 4K (60Hz) digital display capabilities with control of two connected computers.
                4K 60Hz picture and full audio supportThe DisplayPort KVM switch supports resolutions up to 4K at 60Hz and drives four large monitors at the full 4K resolution. Includes USB emulation for faster switching times to avoid disrupting your workflow. With support for digital audio (with supporting displays and sources) and separate 3.5mm stereo audio, the DisplayPort 1.2 KVM switch delivers full audio compatibility.
                Integrated USB hubThe integrated USB 3.0 hub shares two peripherals (in addition to keyboard and mouse) among attached computers as if they were directly connected to your host computer, eliminating the cost of duplicate devices such as printers and scanners.
                Easy to operateThe front-panel pushbuttons make it easy to switch between systems and activate the auto-scan feature. The hotkey functionality makes accessing each system quickly, while a buzzer sound confirms the switch.
- StarTech.com 2 Port Quad Monitor DisplayPort KVM Switch, 4K 60Hz UHD HDR, Desktop 4K DP 1.2 KVM with 2 Port USB 3.0 Hub (5Gbps) & 4x USB 2.0 HID Ports, Audio, Hotkey Switching, TAA - Keyboard/Video/Mouse Switch - KVM / audio switch - 2 ports - TAA Compliant
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- 5.1 channel audio support, HDR support
- USB 1.1, USB 2.0, USB 3.0
- Power
- AC 100-240 V
- Black
- Localisation
- Japan, New Zealand, North America, United Kingdom, Europe
- TAA Compliant
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2160 @ 60 Hz
- Status Indicators
- Status
- 4 x DisplayPort output , 8 x DisplayPort input , 2 x USB 3.0 output Type A , 2 x USB 3.0 input Type B , 4 x USB 1.1 Type A , 2 x audio input mini-jack , 1 x audio output mini-jack
- Power Device
- External power adapter
- Power Provided
- DC 12 V - 3 A
- Voltage Required
- AC 100-240 V
- 36 Watt
- Black
- Included Accessories
- 4 rubber feet
- MTBF
- 156,000 hours
- FCC, RoHS, DisplayPort 1.2, HDCP 2.2
- TAA Compliant
- Localisation
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 60 °C
|  | StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £11.76 |
|  | StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £14.43 |
|  | StarTech.com DisplayPort to DVI Active Adapter | In Stock | £20.81 |
|  | StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £9.84 |
|  | StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £7.41 |
|  | StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £15.11 |
|  | StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter | In Stock | £21.26 |
|  | StarTech.com 2m 6ft USB 3.0 C to B Cable | In Stock | £12.71 |
|  | StarTech.com 3m USB 2.0 C to B Cable | In Stock | £15.57 |
|  | StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £15.26 |
|  | StarTech.com 1m 3.3ft DisplayPort 1.4 Cable | In Stock | £6.91 |
|  | StarTech.com 2m 6.6ft DisplayPort 1.4 Cable | In Stock | £11.85 |
|  | StarTech.com 3m 9.8ft DisplayPort 1.4 Cable | In Stock | £23.17 |
|  | StarTech.com 2-Port DP KVM Switch, 8K 60Hz | In Stock | £297.72 |
|  | StarTech.com 4-Port DP KVM Switch, 8K 60Hz | In Stock | £369.44 |
