StarTech.com 2 Port Quad Monitor DisplayPort KVM Switch
Quicklinx: GGQZWS00 Mfr#: SV231QDPU34K
Type: KVM / audio switch
Connectivity: KVM
Ports: 2
£474.52 ex VAT
£569.42 inc VAT
This two-port KVM switch combines 4K (60Hz) digital display capabilities with control of two connected computers.
  • 4K 60Hz picture and full audio support
    The DisplayPort KVM switch supports resolutions up to 4K at 60Hz and drives four large monitors at the full 4K resolution. Includes USB emulation for faster switching times to avoid disrupting your workflow. With support for digital audio (with supporting displays and sources) and separate 3.5mm stereo audio, the DisplayPort 1.2 KVM switch delivers full audio compatibility.
  • Integrated USB hub
    The integrated USB 3.0 hub shares two peripherals (in addition to keyboard and mouse) among attached computers as if they were directly connected to your host computer, eliminating the cost of duplicate devices such as printers and scanners.
  • Easy to operate
    The front-panel pushbuttons make it easy to switch between systems and activate the auto-scan feature. The hotkey functionality makes accessing each system quickly, while a buzzer sound confirms the switch.
StarTech.com 2 Port Quad Monitor DisplayPort KVM Switch, 4K 60Hz UHD HDR, Desktop 4K DP 1.2 KVM with 2 Port USB 3.0 Hub (5Gbps) & 4x USB 2.0 HID Ports, Audio, Hotkey Switching, TAA - Keyboard/Video/Mouse Switch - KVM / audio switch - 2 ports - TAA Compliant
Subtype
KVM
Ports
2 x KVM / audio
5.1 channel audio support, HDR support
USB 1.1, USB 2.0, USB 3.0
AC 100-240 V
Japan, New Zealand, North America, United Kingdom, Europe
TAA Compliant
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
Status Indicators
Status
4 x DisplayPort output , 8 x DisplayPort input , 2 x USB 3.0 output Type A , 2 x USB 3.0 input Type B , 4 x USB 1.1 Type A , 2 x audio input mini-jack , 1 x audio output mini-jack
External power adapter
Power Provided
DC 12 V - 3 A
AC 100-240 V
36 Watt
4 rubber feet
MTBF
156,000 hours
FCC, RoHS, DisplayPort 1.2, HDCP 2.2
TAA Compliant
0 - 80%
Min Storage Temperature
-10 °C
Max Storage Temperature
60 °C
GGQZ StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.13
GGQZ StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.22
GGQZ StarTech.com DisplayPort to DVI Active Adapter In Stock £21.78
GGQZ StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £10.30
GGQZ StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.07
GGQZ StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £16.43
GGQZ StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £20.93
GGQZ StarTech.com 2m 6ft USB 3.0 C to B Cable In Stock £14.63
GGQZ StarTech.com 3m USB 2.0 C to B Cable In Stock £16.40
GGQZ StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £16.24
GGQZ StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £13.02
GGQZ StarTech.com 2m 6.6ft DisplayPort 1.4 Cable In Stock £15.18
GGQZ StarTech.com 3m 9.8ft DisplayPort 1.4 Cable In Stock £29.12
GGQZ StarTech.com 4-Port DP KVM Switch, 8K 60Hz In Stock £389.40
Connectivity: KVM
Ports: 2
