StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Hotkey Control
Quicklinx: 6LCXWS00 Mfr#: SV231DPU
Share a keyboard, mouse and DisplayPort monitor between 2 high-resolution computer systems. This 2-port USB DisplayPort KVM switch combines the next generation of digital display interface standards with seamless KVM control of connected PC or Mac computers.
Delivering ideal multi-computer control for demanding high-resolution multimedia applications, or computer environments requiring true high definition capability, the robust KVM switch supports DisplayPort connections with a native resolution of 2560 x 1600 (@60 Hz, 30 bpp), as well as 7.1 HD digital audio (when connected to supporting displays and sources).
Suitable for applications that utilize high quality static imaging, such as medical/health care applications (MRI, X-ray diagnostics etc.), the KVM switch supports a maximum resolution of 3840 x 2400 at a reduced refresh rate.
Adding cost-effective performance to cutting-edge multimedia capability, this versatile KVM switch features three Plug-and-Play USB console ports, including two dedicated peripheral (mouse and keyboard) ports and one USB 2.0 hub port - enabling users to share a USB mouse and keyboard, and one USB 2.0 peripheral between the two connected Mac or PC computers.
A simple, yet comprehensive control solution, the 2-port KVM switch features both front-panel push-button and convenient hotkey switching and offers a small form factor design with connection ports situated on the rear panel, allowing you to eliminate workspace disruptions.
The SV231DPU DisplayPort KVM switch guarantees dependable, long-lasting performance.
StarTech.com 2 Port USB DisplayPort KVM Switch with Hotkey Control - KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
KVM Users Qty
1 local user
12.6 cm x 6.5 cm x 4 cm
417 g
3-year warranty
P/N: DP4N1USB6
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2560 x 1600 @ 60 Hz
Status Indicators
Port status
2 x DisplayPort , 2 x keyboard (USB) / mouse (USB) Type B , 3 x USB Type A , 1 x DisplayPort
External power adapter
FCC, RoHS
12.6 cm
6.5 cm
4 cm
417 g
Limited warranty - 3 years
P/N: DP4N1USB6
6LCX StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.80
6LCX StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.94
6LCX StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.24
6LCX StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £8.02
6LCX StarTech.com 6ft 4-in-1 USB DisplayPort KVM Switch Cable with Audio & Microphone In Stock £10.04
6LCX StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
