Easily switch high resolution HD video, keyboard, mouse, and audio with this DisplayPort USB KVM Switch. This 2-Port USB DisplayPort KVM Switch combines the next generation of digital display interface standards with seamless KVM control of connected PC or Mac computers.
Delivering high definition multi-computer control for demanding high-resolution multimedia applications, this robust KVM switch supports DisplayPort connections with a native resolution of 2560 x 1600 (@60 Hz, 30 bpp), as well as 7.1 HD digital audio (when connected to supporting displays and sources).
In addition to offering 7.1 HD digital audio via the DisplayPort connection this two port KVM provides 3.5mm stereo analog audio and microphone switching between the two connected hosts.
Suitable for applications that require high quality static imaging, such as medical/health care applications (MRI, X-ray diagnostics etc.), the KVM switch supports a maximum resolution of 3840 x 2400 at a reduced refresh rate.
Adding cost-effective performance to cutting-edge multimedia capability, this versatile KVM switch features three Plug-and-Play USB console ports, including two dedicated peripheral (mouse and keyboard) ports and one USB 2.0 hub port - enabling users to share a USB mouse and keyboard, and one USB 2.0 peripheral between the two connected computers.
A simple, yet comprehensive control solution, the 2-port KVM switch features both front-panel push-button and convenient hotkey switching and offers a small form factor design with connection ports situated on the rear panel, allowing you to eliminate workspace disruptions.
- StarTech.com 2 Port DisplayPort KVM Switch - 2560x1600 @60Hz - Dual Port DP USB, Keyboard, Video, Mouse Switch Box w/ Audio for Computers and Monitors (SV231DPUA) - KVM / audio switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- KVM Users Qty
- 1 local user
- 22 cm x 13 cm x 4.4 cm
- 1.1 kg
- Black
- 3-year warranty
- Designed For
- P/N: DP4N1USB6, IM12D1500P, SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2400
- Status Indicators
- Port status
- 4 x USB 2.0 Type A , 2 x DisplayPort , 4 x audio mini-jack , 2 x USB 2.0 Type B , 1 x DisplayPort , 2 x audio mini-jack
- Power Device
- External power adapter
- Black
- FCC, RoHS
- 22 cm
- 13 cm
- 4.4 cm
- 1.1 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80%
- Designed For
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.27 |
StarTech.com 4 Port USB DisplayPort KVM Switch with Audio | In Stock | £253.13 |
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £9.68 |
StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio | In Stock | £191.45 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £287.60 |
StarTech.com 6ft 4-in-1 USB DisplayPort KVM Switch Cable with Audio & Microphone | In Stock | £17.35 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.06 |
StarTech.com 2 Port Dual DP KVM Switch - 4K | In Stock | £259.12 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.61 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.02 |
StarTech.com 4 Port DisplayPort KVM Switch 4K 60Hz | In Stock | £377.24 |
StarTech.com 4PT Dual DP KVM Switch 4K60 | In Stock | £599.68 |
StarTech.com 2 Pt DisplayPort KVM | In Stock | £330.09 |
StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz | In Stock | £84.89 |
StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable | In Stock | £95.65 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £12.46 |
