StarTech.com 2 Port PCI RS422/485 Serial Adapter Card with 161050 UART
Quicklinx: 7P0MWS00 Mfr#: PCI2S4851050
Type: Serial adapter
Compatibility: PC
Interface: PCI-X
£73.54 ex VAT
£88.24 inc VAT
The PCI2S4851050 2-Port PCI Serial Adapter Card (RS422/RS485) with 161050 UART adds two DB9 RS422/RS485 serial ports, using a single PCI expansion slot.
The PCI serial card offers a high performance 16C1050 UART and supports both 2-wire and 4-wire RS485 modes. The card delivers an efficient single-chip design and a large 256-byte transit/receive FIFO buffer that work together to provide high-speed serial communication while reducing the overall load on the system CPU.
With the included standard and low profile/half-height brackets, this PCI serial expansion card suits a broad range of system form factors, and is a perfect addition for connecting RS422/485 serial devices to a host computer. For added versatility, the RS422/RS485 adapter is able to accommodate 3.3 or 5V PCI/PCI-X slots.
StarTech.com 2 Port PCI RS422/485 Serial Adapter Card with 161050 UART - Serial adapter - PCI-X - RS-422/485 x 2 - PCI2S4851050 - serial adapter - PCI-X - RS-422/485 x 2
Serial adapter
Plug-in card
Interface (Bus) Type
PCI-X
Ports
RS-422/485 x 2
4.5 cm x 12 cm x 1.8 cm
56 g
RS-422, RS-485
Serial adapter
Plug-in card
PCI-X
Ports
RS-422/485 x 2
RS-422, RS-485
Flow control
2 x RS-422/485 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI-X
4.5 cm
12 cm
1.8 cm
56 g
Limited warranty - lifetime
85 °C
7P0M StarTech.com RS422 RS485 Serial DB9 to Terminal Block Adapter In Stock £11.90
7P0M StarTech.com DB9 RS232 Serial Null Modem Adapter - M/F In Stock £5.23
Compatibility: PC
Interface: PCI-X
