Add 2 high-speed RS-232 serial ports to your PC through a PCI expansion slot. The PCI2S550 2 Port 16550 Serial Card can be installed in an available PCI slot to add two RS232 serial ports to your system. A cost-effective solution for connecting any new or legacy serial device, with data transfer rates of up to 115.2 Kbps.
Perfect for connecting serial modems, POS devices, PDAs, digital cameras, printers, ISDN terminal adapters and more to your system, the adapter card supports IRQ sharing and operates flawlessly with Windows 7, Server 2008 R2, XP, Server 2003, 2000, ME, 98, 95, NT4, 3.1, DOS and Linux.
The card can be connected in minutes through simple plug and play installation.
- StarTech.com 2 Port PCI RS232 Serial Adapter Card with 16550 UART - Serial adapter - PCI - RS-232 x 2 - PCI2S550 - serial adapter - PCI - RS-232 x 2
- Serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- Ports
- RS-232 x 2
- Data Link Protocol
- Serial
- Data Transfer Rate
- 115.2 Kbps
- System Requirements
- Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- Limited lifetime warranty
- Serial adapter
- Form Factor
- Plug-in card
- PCI
- Ports
- RS-232 x 2
- Connectivity Technology
- Wired
- Serial
- 115.2 Kbps
- 2 x RS-232 - 9 pin D-Sub (DB-9) - male - 2
- Compatible Slots
- 1 x PCI
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - parts and labour - lifetime - carry-in
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.43 |
StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD | In Stock | £158.99 |
