StarTech.com 2 Port PCI IDE Controller Adapter Card
Quicklinx: 4M6CWS00 Mfr#: PCIIDE2
Type: Storage controller
Controller Interface: ATA-133
Interface: PCI
Compatibility: PC
Hurry, only 1 left in stock!
£23.50 ex VAT
£28.20 inc VAT
This 2 Port IDE (Ultra ATA/133) Controller Card can be installed in a PCI slot, to add more IDE storage capability to your PC.
Providing two IDE drive channels with support for two drives per channel and data transfer rates of up to 133 MBps, this adapter card can act as the primary boot device and replace built-in IDE ports, or provide 2 additional high-speed ports to the system. Designed to perform with high-speed IDE/133 drives, the adapter card also supports 100 MBps hard drives, 66 MBps hard drives, 33 MBps hard drives, CD-ROMS, CDRW drives, and other ATA peripherals.
To ensure hassle-free installation, the IDE Controller Card includes Bus-Master drivers for DOS, Windows 98/ME/NT 4/2000/XP and Vista.
StarTech.com 2 Port PCI IDE Controller Adapter Card - storage controller - ATA-133 - PCI
Storage controller - plug-in card
Bus Type
PCI
ATA-133
Data Transfer Rate
133 MBps
Supported Devices
Hard drive, CD drive, DVD drive, MO disk drive
Channel Qty
2
Max Storage Devices Qty
4
Microsoft DOS, Microsoft Windows NT 4.0, Microsoft Windows Server 2003, Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista, Windows 10 (32/64 bits)
12 cm x 8.5 cm
Host Bus
PCI
Storage Controller
ATA-133
Data Transfer Rate
133 MBps
Supported Devices
Channel Qty
2
4
2 x ATA-133 - 40 PIN IDC (internal)
Compatible Slots
1 x PCI
2 x IDE cable
FCC, RoHS
Software Included
Drivers & Utilities
Limited warranty - lifetime
12 cm
8.5 cm
Interface: PCI
Compatibility: PC
Price Range Ex VAT: 0 - 50
