This 2 Port IDE (Ultra ATA/133) Controller Card can be installed in a PCI slot, to add more IDE storage capability to your PC.
Providing two IDE drive channels with support for two drives per channel and data transfer rates of up to 133 MBps, this adapter card can act as the primary boot device and replace built-in IDE ports, or provide 2 additional high-speed ports to the system. Designed to perform with high-speed IDE/133 drives, the adapter card also supports 100 MBps hard drives, 66 MBps hard drives, 33 MBps hard drives, CD-ROMS, CDRW drives, and other ATA peripherals.
To ensure hassle-free installation, the IDE Controller Card includes Bus-Master drivers for DOS, Windows 98/ME/NT 4/2000/XP and Vista.
- StarTech.com 2 Port PCI IDE Controller Adapter Card - storage controller - ATA-133 - PCI
- Storage controller - plug-in card
- Bus Type
- PCI
- Interface
- ATA-133
- Data Transfer Rate
- 133 MBps
- Supported Devices
- Hard drive, CD drive, DVD drive, MO disk drive
- Channel Qty
- 2
- Max Storage Devices Qty
- 4
- System Requirements
- Microsoft DOS, Microsoft Windows NT 4.0, Microsoft Windows Server 2003, Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista, Windows 10 (32/64 bits)
- 12 cm x 8.5 cm
- Limited lifetime warranty
- Host Bus
- PCI
Storage Controller
- Interface
- ATA-133
- 133 MBps
- Supported Devices
- Channel Qty
- 2
- 4
- 2 x ATA-133 - 40 PIN IDC (internal)
- Compatible Slots
- 1 x PCI
- Cables Included
- 2 x IDE cable
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - lifetime
- 12 cm
- 8.5 cm
