StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External
Quicklinx: 76PDWS00 Mfr#: PEXUSB3S11
Type: USB adapter
Compatibility: PC
Interface: PCI Express 2.0
36 in stock
£24.55 ex VAT
£29.46 inc VAT
Add one internal and one external SuperSpeed USB 3.0 to your PC. The PEXUSB3S11 PCI Express USB 3.0 Card lets you add one internal, and one external USB 3.0 port to your PC through a PCI Express slot.
Featuring a native NEC PCI Express host controller chipset, the new USB 3.0 standard supports transfer rates of up to 5Gbps, while still providing backward compatibility with older USB 2.0 (480Mbps) and 1.1 (12Mbps) devices. The inclusion of an internal USB 3.0 connection provides the added benefit of compatibility with USB 3.0-based internal storage solutions or front-bay hubs.
Enhanced with UASP support (USB Attached SCSI Protocol), this USB 3.0 controller performs up to 70% faster than conventional USB 3.0 when paired with a UASP supported enclosure (Note: UASP requires a compatible operating system). Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP technology optimizes transfers by allowing multiple commands to be processed simultaneously, significantly increasing transfer speeds for less wait time on data transfers.
For bus-powered USB devices, this PCIe USB 3.0 card includes an optional SATA power connector to connect to your system power supply and deliver up to 900mA of power per port to USB 3.0 devices (500mA for USB 2.0).
UASP is supported in Windows 8, Server 2012 and Linux kernel 2.6.3 or later. In testing UASP performed with up to a 70% faster read / 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing, UASP also showed up to an 80% reduction in required processor resources.
Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.0 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External - Dual Port PCIe USB 3.0 Adapter (PEXUSB3S11) - USB adapter - 2 ports
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0
7.6 cm x 12.1 cm x 1.9 cm
40 g
Ports Qty
2 ports
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2
P/N: HB20A4AME, HB20A7AME, S2510BPU337, S251BU31315, S3510BMU33, S3510SMU33, S3540BU33E, SATDOCK2REU3, SDOCK2ERU33, SDOCK2U313R, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCK4U33, SDOCKU33BV, SDOCKU33EBV, SDOCKU33HW, SM2NGFFMBU33, UNI251BMU33, UNIDOCKU33, USB3S2ESATA3, USB3S2SAT3CB
PCI Express 2.0
Wired
USB, USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
1 x USB 3.0 - 9 pin USB Type A (external) , 1 x USB 3.0 - 9 pin USB Type A (internal)
Compatible Slots
1 x PCI Express 2.0
Low-profile bracket
FCC, RoHS
7.6 cm
12.1 cm
1.9 cm
40 g
Limited warranty - lifetime
50 °C
0 - 85%
P/N: 35BAYUSB3S4, HB20A4AME, HB20A7AME, S2510BMU33, S2510BPU33, S2510BPU337, S251BU31315, S3510BMU33, S3510SMU33, S3540BU33E, SATDOCK2REU3, SDOCK2ERU33, SDOCK2U313R, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCK4U33, SDOCKU33BV, SDOCKU33EBV, SDOCKU33HW, SM2NGFFMBU33, ST4300USB3, ST4300USB3EU, ST4300USB3GB, ST4300USBM, UNI251BMU33, UNIDOCKU33, USB3S2ESATA3, USB3S2SAT3CB, USB3SAB1
76PD StarTech.com 6 ft SuperSpeed USB 3.0 Cable A to A - M/M In Stock £6.28
76PD StarTech.com 10 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £7.74
76PD StarTech.com 3 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £2.92
76PD StarTech.com 6 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £4.92
76PD StarTech.com 7 Port PCI USB Card Adapter In Stock £14.87
76PD StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £24.55
Type: USB adapter
Compatibility: PC
Price Range Ex VAT: 0 - 50
