StarTech.com 2-Port PCI Express Serial Card
Quicklinx: CPBVWS00 Mfr#: PEX2S1050
Type: Serial adapter
Compatibility: PC, Unix
Interface: PCI Express x1
21 In Stock
£39.75 ex VAT
£47.70 inc VAT
Add two high performance RS232 serial ports (DB9) to your low or full-profile computer, through a PCI Express slot. This PCI Express serial card adds two high-performance RS232 serial ports to your desktop computer or server, for connecting your serial-based devices and equipment.
The PCIe serial card can be installed into an available PCI Express slot, to provide two high-performance 16C1050 RS232 serial UART channels/ports. It offers a convenient solution for connecting modern or legacy equipment to newer computer systems that don't have RS232 ports. The serial card is compliant with PCI Express 1.0a specification, and it's compatible with 1x, 2x, 4x, 8x and 16x PCI Express slots.
The 2-port PCIe serial card is ideal for system upgrades in a wide range of applications including manufacturing equipment, POS equipment, security devices such as surveillance cameras, card readers or access panels, and environment or building control systems.
The PCIe serial card delivers high-performance serial communication, with support for data transfer rates of up to 460Kbps. The serial card provides CPU load decrease which helps ensure optimal system performance and prevent errors such as overruns by preserving resources. In addition, the dual-channel UART ensures smooth performance, even while both ports are in use.
The serial card is easy to install and configure, with support for a broad range of Windows operating systems. Plus, the card features IRQ sharing and supports plug-and-play serial device connections, guaranteeing convenient, hassle-free installation. It comes with a standard-profile bracket installed, and also includes an optional low-profile bracket.
  • Reliable connectivity
    This serial adapter features two RS-232 connections that ensure dependable data communication for various applications, from industrial devices to legacy systems.
  • Efficient data transfer
    With a maximum data transfer rate of 460.8 Kbps, this serial card enables swift communications essential for applications requiring quick response times.
  • Wide environmental range
    Operating between -10°C and 80°C, this card maintains functionality in diverse environments, making it suitable for different operating conditions.
  • Seamless installation
    Designed as a low-profile plug-in card, it fits into compact space constraints while connecting to PCI Express x1 slots without hassle.
  • Standards compliant
    This serial card meets WHQL, FCC, RoHS, and WEEE standards, ensuring it adheres to safety and environmental regulations while providing a reliable solution.
StarTech.com 2-Port PCI Express Serial Card with 16C1050 UART - RS232 Low Profile Serial Card - PCI Serial Card (PEX2S1050) - serial adapter - PCIe - RS-232 x 2
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0a
Ports
RS-232 x 2
12 cm x 10.3 cm x 2 cm
61 g
RS-232
Data Transfer Rate
460.8 Kbps
Microsoft Windows 95, Microsoft Windows 98 Second Edition, Microsoft Windows Millennium Edition, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Linux 2.4 - 2.6.x
Serial adapter
PCI Express x1
PCIe 1.0a
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
460.8 Kbps
Software flow control, full duplex mode, 128-byte FIFO
2 x RS-232 - 9 pin D-Sub (DB-9)
2 x low-profile bracket
WHQL, FCC, RoHS, WEEE
Software Included
Drivers & Utilities
12 cm
10.3 cm
2 cm
61 g
-10 °C
80 °C
5 - 85%
CPBV StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
CPBV StarTech.com 2 Port PCI Express RS232 Serial Adapter Card In Stock £36.05
CPBV StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD In Stock £155.21
CPBV StarTech.com 1-Prt PCI Express Serial Card In Stock £36.98
CPBV StarTech.com PCIe Dual Serial Port Card In Stock £38.53
CPBV StarTech.com PCIe Dual Serial Port Card In Stock £42.80
Compatibility: PC
Compatibility: Unix
