Add 2 RS232 serial ports to your standard or small form factor computer through a PCI Express expansion slot. The PEX2S950 2 Port PCI Express RS232 Serial Adapter Card with 16950 UART can be installed into an available PCI Express slot, to provide two high performance 16C950 RS232 serial UART channels/ports - a convenient solution for connecting modern or legacy serial devices with support for data transfer rates of up to 460 Kbps.
The 2 port RS232 serial card is easy to install and configure, with support for a broad range of Windows operating systems. Plus, the card features IRQ sharing and supports plug and play serial device connections, guaranteeing convenient, hassle-free installation.
- StarTech.com 2 Port PCI Express RS232 Serial Adapter Card with 16550 UART - serial adapter - PCIe - RS-232 x 2
- Serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- Ports
- RS-232 x 2
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 460 Kbps
- System Requirements
- Microsoft Windows 95, Microsoft Windows 98, Microsoft Windows Millennium Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 10 (32/64 bits)
- Limited lifetime warranty
- Serial adapter
- Form Factor
- Plug-in card
- PCI Express x1
- Ports
- RS-232 x 2
- Connectivity Technology
- Wired
- RS-232
- 460 Kbps
- Hardware flow control
- 2 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI Express x1
- Plug and Play, WHQL, FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - lifetime
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.43 |
