StarTech.com 2 Port PCI Express RS232 Serial Adapter Card
Quicklinx: FSHWWS00 Mfr#: PEX2S953
Type: Serial adapter
Compatibility: PC
Interface: PCI Express x1
More than 50 In Stock
£36.05 ex VAT
£43.26 inc VAT
PCI Express to Serial Adapter 921.6Kbps Windows and Linux Compatible. This multiport PCI Express RS232 serial adapter card lets you add two RS232 (DB9) serial ports to your computer through a PCI Express (PCIe) slot, as if they were native serial ports. The dual port PCIe serial card enables you to interact with serial devices, such as card readers, printers, PIN pads, and modems, at speeds of up to 921.6Kbps.
Maximum Compatibility
With broad OS support, including for Windows and Linux, this 2 port PCI E serial card is easy to integrate into mixed environments. The card comes pre-configured with a full-profile bracket, and includes optional low-profile brackets, so installation is easy regardless of the case form factor. This card is a direct replacement for PEX2S952(LINK).
Experience Optimal Technology
This PCIe to serial adapter supports the following features:
Industry standard 16950 UART compatible
Supports max baud rate of up-to 921.6Kbps
Provides 5/12V power output on Pin 9 when external power is connected
256-byte depth FIFO cache per transmitter and receiver
Supports 9, 8, 7, 6, 5 data bits (one per port)
Asix AX99100 chipset
Base PCI Express 1.1 compliant
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
PEX2S953 is backed by a StarTech.com lifetime warranty and free lifetime technical support.
  • Maximum Compatibility
    With broad OS support, including for Windows and Linux, this 2 port PCI E serial card is easy to integrate into mixed environments. The card comes pre-configured with a full-profile bracket, and includes optional low-profile brackets, so installation is easy regardless of the case form factor. This card is a direct replacement for PEX2S952 .
  • Experience Optimal Technology
    This PCIe to serial adapter supports the following features: • Industry standard 16950 UART compatible • Supports max baud rate of up-to 921.6Kbps • Provides 5/12V power output on Pin 9 when external power is connected • 256-byte depth FIFO cache per transmitter and receiver • Supports 9, 8, 7, 6, 5 data bits (one per port) • Asix AX99100 chipset • Base PCI Express 1.1 compliant • Low and full-profile brackets included
  • The Choice of IT Pros Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. PEX2S953 is backed by a StarTech.com lifetime warranty and free lifetime technical support.
StarTech.com 2-port PCI Express RS232 Serial Adapter Card, PCIe RS232 Serial Host Controller Card, PCIe to Dual Serial DB9 COM Port Card, 16950 UART, Expansion Card, Windows, macOS, Linux - Full/Low-Profile (PEX2S953) - serial adapter - PCIe - RS-232 x 2
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.1
Ports
RS-232 x 2
7.5 cm
RS-232
Data Transfer Rate
921.6 Kbps
ASIX AX99100
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x - 2.6.x LTS versions only
Serial adapter
Plug-in card
PCI Express x1
PCIe 1.1
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Full duplex mode, 256-byte FIFO
Processor / Memory
ASIX AX99100
2 x RS-232 - 9 pin D-Sub (DB-9) , 1 x SATA power - 15 pin Serial ATA power (internal)
2 x low-profile bracket
WHQL, FCC, RoHS, WEEE
7.5 cm
Shipping Weight
146.4 g
Limited warranty - lifetime
-10 °C
80 °C
5 - 85%
FSHW StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.57
FSHW StarTech.com PCIe Card with Serial and Parallel Port - PCI Express Combo In Stock £33.98
Compatibility: PC
