Add 2 internal SATA 2.0 ports to your desktop computer through a PCI Express expansion slot. This 2 Port PCI Express Internal Serial ATA Controller Card adds two internal SATA II (SATA /300) ports to a computer through simple installation into an available 1x PCI Express slot.
Supporting data transfer speeds of up to 3.0 Gbps, the SATA controller card features Port Multiplier support with command-based switching as well as Native Command Queuing to ensure optimum performance.
Using a native PCI Express single chipset, the internal SATA controller card provides enhanced compatibility, reliability and performance for your external storage needs. The controller card also features Port Multiplier support with command based switching for connecting multiple external hard drives to a host computer through one eSATA connection.
The controller card includes both standard form factor and low profile brackets, allowing you to add SATA capability to virtually any PCI Express enabled computer, regardless of the case form factor.
- StarTech.com 2 Port PCI Express Internal SATA Controller Card - storage controller (RAID) - SATA 3Gb/s - PCIe x1
- Storage controller (RAID) - plug-in card
- Bus Type
- PCIe x1
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 3 Gbit/s
- Supported Devices
- Disk array (RAID)
- RAID Level
- RAID 0, RAID 1, JBOD
- System Requirements
- Linux, Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- Limited lifetime warranty
- Host Bus
- PCIe x1
Storage Controller
- Interface
- SATA 3Gb/s
- 3 Gbit/s
- Supported Devices
- Disk array (RAID)
- RAID Level
- 2 x SATA 3Gb/s - SATA (internal)
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - lifetime
StarTech.com 24" Serial ATA Cable | In Stock | £5.28 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £2.50 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.70 |
