Add 2 eSATA ports to your desktop computer through a PCI Express expansion slot. This 2 Port PCI Express eSATA Controller Adapter Card offers simple connectivity between a host computer and eSATA devices. Providing two eSATA ports the adapter card offers a cost-effective solution for connecting hot-pluggable, high-speed storage, and in turn allows for easier data backups and archiving.
With full support for SATA 300 (SATA II) hard drives and data transfer speeds of up to 3 Gbps, the adapter card features a native PCI Express single chipset that provides enhanced compatibility, reliability and performance for external SATA storage needs.
The PCI Express eSATA controller card also features port multiplier capability with command-based switching for connecting multiple external hard drives to a host Windows system through a single external SATA connection.
A dual profile solution, the eSATA controller card includes a low profile/half-height bracket for adapting to slimline or small form factor system applications.
- StarTech.com 2 Port PCI Express eSATA Controller Adapter Card - storage controller - eSATA 3Gb/s - PCIe x1
- Storage controller - plug-in card - low profile
- Bus Type
- PCIe x1
- Interface
- eSATA 3Gb/s
- Channel Qty
- 2
- Max Storage Devices Qty
- 2
- System Requirements
- Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- Limited lifetime warranty
- Designed For
- P/N: S3540BU33E, SDOCKU33EBV
- Host Bus
- PCIe x1
Storage Controller
- Interface
- eSATA 3Gb/s
- Channel Qty
- 2
- 2
- 2 x SATA 3Gb/s - eSATA (external)
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - lifetime
- Designed For
StarTech.com 6 ft Shielded External eSATA Cable M/M | In Stock | £10.50 |
