StarTech.com 2-Port PCI Express 10GBase-T Ethernet Network Card
Quicklinx: BNPPWS00 Mfr#: ST20000SPEXI
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Fast Ethernet, 10 Gigabit Ethernet
Compatibility: Unix, PC
Type: Network adapter
21 in stock
£269.50 ex VAT
£323.40 inc VAT
Add two 10 Gigabit Ethernet ports (10Gbps) to a client, server or workstation through one PCI Express slot. Now, you can add 10 GbE networking, while minimizing your deployment costs. This 10Gbase-T network card (NIC) lets you add two RJ45 ports through a single PCI Express slot, to deliver reliable high-speed network connections to your workstations and servers without draining your budget.
Compatible with a broad range of operating systems, this versatile dual-port NIC is ideal for many business applications that require upgrades to servers or workstations. It's a cost-effective way to enhance your server or computer capabilities by adding two powerful 10-Gigabit Ethernet ports, with support for advanced features such as VLAN tagging, jumbo frames, Wake-On LAN and Auto-MDIX.
This 2-port PCI Express 10GBase-T network card features the Intel X540 chipset, designed to deliver the power, performance and enhanced capabilities you need for reliable network connections to your server or computer. The X540 chipset provides many advanced features including Intel Virtualization Technology for connectivity and PXE network boot support.
Compliant with IEEE 802.3/u/ab standards, the network card delivers a dependable way to upgrade or replace your existing network ports with dual 100/1000/10G compatible RJ45 ports, providing throughput capability of up 10Gbps in each direction (20Gbps total). It connects through a single, four-lane (x4 or higher) PCI Express slot.
With a dual-profile design, the PCI Express network card installs easily into a wide range of computer/server chassis, regardless of form factor. The card comes equipped for installation in a full-sized chassis, and includes a low-profile/half-height installation bracket that you can use as needed.
StarTech.com 2-Port 10Gb PCIe NIC with Native Link Aggregation - 10Gbase-t Ethernet Card - 100/1000/10000 Mbps LAN Card (ST20000SPEXI) - network adapter - PCIe 2.0 x8 - 10Gb Ethernet x 2
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x8
PCI Specification Revision
PCIe 2.0
Ports
10Gb Ethernet x 2
2 cm x 16.3 cm x 12 cm
160 g
Cabling Type
Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T
100Mb LAN, GigE, 10 GigE
Data Transfer Rate
10 Gbps
Performance
Forwarding performance (full duplex): 20 Gbps
Jumbo frame size: 15000
Intel x540
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.3an, IEEE 802.3az
Microsoft Windows Server 2008 R2 x64 Edition, VMware ESXi 5.1, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, VMware ESXi 5.5, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019 (64-bit)
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, ET10GSFP, TB31PCIEX16
Network adapter
PCI Express 2.0 x8
PCIe 2.0
Ports
10Gb Ethernet x 2
Wired
Cabling Type
Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Performance
Status Indicators
Port status, link/activity
Full duplex capability, auto-uplink (auto MDI/MDI-X), Jumbo Frames support, Link Aggregation Control Protocol (LACP)
Processor / Memory
Intel x540
2 x 10GBase-T - RJ-45
Low-profile bracket
FCC, RoHS
2 cm
16.3 cm
12 cm
160 g
5 °C
50 °C
20 - 80%
BNPP StarTech.com 10 ft Cat 6a Blue Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable In Stock £13.71
BNPP StarTech.com 10 ft Cat 6a Gray Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable In Stock £13.71
BNPP StarTech.com Dual Port PCI Express (PCIe x4) Gigabit Ethernet Server Network Card - Intel i350 NIC In Stock £114.11
Protocol: Fast Ethernet
Protocol: 10 Gigabit Ethernet
Compatibility: Unix
Compatibility: PC
Stock Status: In stock
