StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power
Quicklinx: 9C4HWS00 Mfr#: PEXUSB3S24
Type: USB adapter
Compatibility: PC
Interface: PCI Express x1
  • Windows 8 (32/64 bits)
15 in stock
£21.21 ex VAT
£25.45 inc VAT
Add 2 SuperSpeed USB 3.0 ports with SATA power to your PCI Express-enabled PC. The PEXUSB3S24 2-Port PCI Express USB 3.0 Card lets you add two USB 3.0 ports to your PCI Express-enabled computer system, with an optional SATA power connector to connect to your system power supply and deliver up to 900mA of power per port to USB 3.0 bus-powered devices (500mA for USB 2.0).
Enhanced with UASP support (USB Attached SCSI Protocol), this USB 3.0 controller performs up to 70% faster than conventional USB 3.0 when paired with a UASP supported enclosure (Note: UASP is not supported by all operating systems). Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP technology optimizes transfers by allowing multiple commands to be processed simultaneously, significantly increasing transfer speeds for less wait time on data transfers.
The PCIe USB 3.0 adapter is compliant with USB 3.0 standards for data transfer speeds up to 5 Gbps, while still offering backward compatibility with existing USB 2.0 / 1.1 devices. For added versatility, the controller card is equipped with a standard profile bracket and includes a low-profile/half-height bracket for installation in small form-factor computers.
UASP is supported in Windows 8, 8.1, Server 2012 and Linux kernel 2.6.37 or later. In testing UASP performed with up to a 70% faster read / 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing, UASP also showed up to an 80% reduction in required processor resources.
Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.0 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
StarTech.com 2 Port PCI Express (PCIe) USB 3.0 Card with UASP - SATA Power - USB adapter
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports
USB 3.0 x 2
2.2 cm x 6 cm x 6.5 cm
56 g
USB 3.0
Data Transfer Rate
5 Gbps
USB 3.0
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
USB adapter
Plug-in card
PCI Express x1
Ports
USB 3.0 x 2
Wired
SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
USB 3.0
2 x USB 3.0 - 9 pin USB Type A (external)
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
2.2 cm
6 cm
6.5 cm
56 g
5 °C
50 °C
20 - 80%
9C4H StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £23.84
9C4H StarTech.com 10 ft Black SuperSpeed USB 3.0 Cable A to B - M/M In Stock £9.33
9C4H StarTech.com 3 ft Black SuperSpeed USB 3.0 Cable A to B - M/M In Stock £4.72
9C4H StarTech.com 6 ft Black SuperSpeed USB 3.0 Cable A to B - M/M In Stock £4.84
9C4H StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £73.16
9C4H StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £30.85
9C4H StarTech.com 2 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card w/ SATA Power In Stock £15.89
9C4H StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power In Stock £18.53
9C4H StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £62.49
9C4H StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels In Stock £63.98
9C4H StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £71.38
9C4H StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power In Stock £21.21
Type: USB adapter
Compatibility: PC
Price Range Ex VAT: 0 - 50
