StarTech.com 2 Port PCI Express / PCI-e Parallel Adapter Card – IEEE 1284 with Low Profile Bracket
Quicklinx: 8BM0WS00 Mfr#: PEX2PECP2
Type: Parallel adapter
Compatibility: PC
Interface: PCI Express x1
  • Windows 8 (32/64 bits)
£13.98 ex VAT
£16.77 inc VAT
Add 2 high-speed IEEE 1284 parallel ports (EPP/ECP/SPP/PS2) to your desktop computer through a PCI Express expansion slot. The PEX2PECP2 2 Port PCI Express Parallel Adapter Card - EPP/ECP/SPP/PS2 parallel card adds two IEEE 1284 parallel ports to your PC, with support for parallel data communication at speeds of up to 1.5 Mbps.
This high performance 2 Port PCI Express parallel card adds 2 DB25 parallel ports, perfect for connecting printers, scanners, memory card readers, bar code scanners and more. With the added convenience of plug-and-play capability, installing the parallel adapter card is hassle-free. The PCIe Parallel card also includes both standard and half-height/low profile mounting brackets for compatibility with almost any system form factor.
StarTech.com 2 Port PCI Express / PCI-e Parallel Adapter Card - IEEE 1284 with LP Bracket - 2x DB25 (F) PCIE Parallel Port Card (PEX2PECP2) - parallel adapter - PCIe - IEEE 1284 x 2
Parallel adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports
IEEE 1284 x 2
1.9 cm x 12.1 cm x 6.7 cm
60 g
Parallel
Data Transfer Rate
1.5 Mbps
Linux, Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Parallel adapter
Plug-in card
PCI Express x1
Ports
IEEE 1284 x 2
Wired
Parallel
Data Transfer Rate
1.5 Mbps
2 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
Compatible Slots
1 x PCI Express x1
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
1.9 cm
12.1 cm
6.7 cm
60 g
Limited warranty - lifetime
5 - 85% (non-condensing)
Compatibility: PC
