StarTech.com 2-Port NIC - PCIe 10G/NBASE-T
Quicklinx: D3VGWS00 Mfr#: ST10GPEXNDPI
Hurry, only 3 left in stock!
£333.66 ex VAT
£400.39 inc VAT
Add two Ethernet ports to a server or workstation through one PCI Express slot, with support for five network speeds: 10G/5G/2.5G/1G/100Mbps. This dual-port network card offers versatile and cost-efficient network connectivity, by increasing the available network bandwidth without having to replace your existing cabling infrastructure. The 5-speed network card lets you add two 10G/NBASE-T RJ45 ports to your server or desktop computer and access your network at multiple speeds: 10G, 5G, 2.5G, 1G, and 100Mbps.
Compatible with a broad range of operating systems, this versatile dual-port NIC is ideal for many business applications that require upgrades to servers or workstations. Fully compliant with 10GBASE-T and NBASE-T specifications, the network card is a cost-effective way to enhance your server or computer capabilities by adding two powerful 10-Gigabit Ethernet ports. (10G network speeds require Cat6a cable. All other speeds require Cat5e cable.)
The network card supports advanced NBASE-T technology, compatible with the latest multi-gigabit Ethernet switches and routers, such as new Cisco campus switches (including Catalyst 4500E, 3850 and 3560-CX). The card enables you to connect to NBASE-T based equipment at network speeds of 2.5Gbps or 5Gbps, over your existing Cat5e infrastructure, without having to upgrade to more expensive Cat6a.
NBASE-T technology accelerates the speed of twisted pair Cat5e copper cabling over a distance of up to 100 meters. The Ethernet network card also supports 10Gbps network speeds if using Cat6a cabling, and 1Gbps network speeds if using Cat5e (or better) cabling.
The Ethernet ports are based on the Intel X550 chipset, designed to deliver the power, performance, and enhanced capabilities you need for reliable network connections to your server or computer. The network card also supports advanced features including 9K jumbo frames and 802.1q VLAN tagging.
With a dual-profile design, the PCI Express network card installs easily into a wide range of computer/server chassis, regardless of form factor. The card comes equipped with a standard-profile bracket for installation in a full-sized chassis and includes a low-profile/half-height bracket for installation in small form-factor computers.
StarTech.com Dual Port 10G PCIe Network Adapter Card - Intel-X550AT 10GBASE-T PCI Express 10GbE Multi Gigabit Ethernet 5 Speed NIC 2port - network adapter - PCIe 3.0 x4 - 10Gb Ethernet x 2
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 3.0 x4
PCI Specification Revision
PCIe 3.0
Ports
10Gb Ethernet x 2
1.8 cm x 15 cm x 12 cm
215 g
Cabling Type
Ethernet 10GBase-T
100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
Network / Transport Protocol
TCP/IP, UDP/IP, iSCSI
Intel
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3an, IEEE 802.3az
Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 3.x - 4.11 LTS versions, Microsoft Windows Server 2019 (64-bit)
Network adapter
PCI Express 3.0 x4
PCIe 3.0
Ports
10Gb Ethernet x 2
Wired
Cabling Type
Ethernet 10GBase-T
Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
Status Indicators
Link/activity/speed
Auto-uplink (auto MDI/MDI-X), full duplex mode, PXE support, tagged VLAN, 9 KB Jumbo Frame
Processor / Memory
Intel
2 x 10GBase-T - RJ-45
Low-profile bracket
1.8 cm
15 cm
12 cm
215 g
5 °C
50 °C
20 - 80%
D3VG StarTech.com 1 Port PCI Express PCIe Gigabit Network Server Adapter NIC Card - Dual Profile In Stock £18.74
D3VG StarTech.com 1-Port Gigabit NIC - PCIe In Stock £28.06
Wired / Wireless: Wired
Protocol: 10 Gigabit Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Protocol: 2.5 Gigabit Ethernet
Protocol: 5 Gigabit Ethernet
Compatibility: PC
Type: Network adapter
