Efficient networking capability
The network adapter supports a data transfer rate of 1 Gbps, suitable for high-performance networking requirements. -
Versatile connectivity options
With two available RJ-45 ports, this adapter card allows for multiple connections to your network. -
Wide temperature tolerance
Operating effectively within a temperature range of 5°C to 70°C ensures stability in various environments. -
Comprehensive compatibility
This adapter complies with IEEE standards, ensuring it meets the necessary requirements for effective network integration. -
User-friendly installation
The Plug-and-Play feature simplifies setup, allowing quick deployment without complicated configurations.
StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable | In Stock | £206.76 |
StarTech.com 1-Port Network Card, TAA | In Stock | £22.01 |
