StarTech.com 2-Port Network Card, TAA
Quicklinx: J1L8WS00 Mfr#: ST1000SPEXD4T
Hurry, only 1 left in stock!
£88.50 ex VAT
£106.20 inc VAT
  • Efficient networking capability
    The network adapter supports a data transfer rate of 1 Gbps, suitable for high-performance networking requirements.
  • Versatile connectivity options
    With two available RJ-45 ports, this adapter card allows for multiple connections to your network.
  • Wide temperature tolerance
    Operating effectively within a temperature range of 5°C to 70°C ensures stability in various environments.
  • Comprehensive compatibility
    This adapter complies with IEEE standards, ensuring it meets the necessary requirements for effective network integration.
  • User-friendly installation
    The Plug-and-Play feature simplifies setup, allowing quick deployment without complicated configurations.
J1L8 StarTech.com 1-Port Network Card, TAA In Stock £22.69
