Connect 2 internal USB 3.0 devices (internal card reader, hard drive) directly to a motherboard header connection. The USB3SMBADAP6 Internal USB 3.0 Adapter Cable extends a 20-pin motherboard USB 3.0 header connection and enables you to add 2 internal female USB 3.0 (Type A) ports.
With the addition of the 2 internal USB 3.0 ports, you can connect your internal devices (internal card reader, hard drive, etc.) directly to your motherboard, which allows for a cleaner installation, avoiding the need to run your cables outside the system case to external USB 3.0 ports.
This USB 20-pin Adapter offers 6-inches in cable length, which lessens strain on the motherboard header, ensuring a reliable, long-lasting connection.
- StarTech.com 2 Port Internal USB 3.0 Motherboard Header Adapter Cable - Internal 20-pin Header to 2x USB 3.0 A Female Adapter Cable - 6in (USB3SMBADAP6) - USB internal adapter - USB Type A to 20 pin USB 3.0 header - 15.24 cm
- Technology
- Shielded
- Length
- 15.24 cm
- Connector
- 2 x 9 pin USB Type A - female
- Connector (Second End)
- 20 pin USB 3.0 header - female
- USB / USB 2.0 / USB 3.0
- Black
- Limited lifetime warranty
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 15.24 cm
- Black
- Connector
- USB / USB 2.0 / USB 3.0, RoHS
